I have Windows 7. I tried to install Ubuntu and the installation was almost over when an error message popped up and the installation failed. Then I rebooted the computer but the computer wont start. A blank screen appeared and nothing is happening. The same thing is happening every time I am starting my computer. How can I solve it? Please help.
Asked
Active
Viewed 243 times
Try to hold down the Shift key during PC boot and see if a boot menu appears
or
try to use the boot-repair program from a LiveCD-USB of Ubuntu to repair the bootloader.
NickTux
- 17,865
- 6
- 57
- 66
At this point, the easiest thing is probably to install Ubuntu again. If it fails a second time, make a note of the exact error message so you can put it in a question. As it is now, there's not too much anyone can say to help you as you haven't given sufficient information.
Scott Severance
- 14,336
To fix grub boot loder follow this guide.
You need Ubuntu 12.04 livecd for repairing grub boot loader . Here assuming the Ubuntu partition is sda7. Boot up ubuntu from the livecd,open terminal and run:
sudo -i and see what is your linux partition and note it I assume it sda7 here.
mount /dev/sda7 /mnt
mount /dev/sda7 /mnt/boot
grub-install --root-directory=/mnt/ /dev/sda
mount --bind /proc /mnt/proc
mount --bind /dev /mnt/dev
mount --bind /sys /mnt/sys
chroot /mnt update-grub
umount /mnt/sys
umount /mnt/dev
umount /mnt/proc
exit
KK Patel
- 19,753
