I went here and downloaded a theme named Ubuntaero_v1.0. Then I extracted the files to /usr/share/icons. After rebooting the system, the default cursor theme remains, except when moving the mouse over some applications' windows, such as KeepassX.
However, when I take a screenshot of that same window, the outcome shows the default cursor again.
Then I went to terminal:
sudo update-alternatives --config x-cursor-theme
The ubuntaero theme is not listed. It seems I am missing something in installing a cursor theme. What could it be?
Neptunno
  • 2,254
  • 25
  • 41
First of all, change the permission of extracted directory (including sub-directories and files) to 755:
sudo chmod -R 755 cursors/
Then change the theme presented in /usr/share/icons/default/index.theme to your Cursor theme
Then Select it in gnome-tweak-tool
I've tried every instructions and it didn't work (default Arrow cursor remained DMZ-White), until i changed the permission.
Hope it helps.
Nevercom
  • 327
