Whats common among Skype, Opera, OpenOffice in Ubuntu ? Whenever I open these applications I get logged off and shows back me the login screen. This started happening since the 10.10 upgrade.
Forgot to mention :
  1. Yes, its x64.
  2. Each time I open these applications, the UI shows and then crashes.
I started each app & logged the last few lines of /var/log/syslog after each crash. Looks like something to do with sound drivers ?
Opera :
Jan  8 09:33:20 al-ubuntu pulseaudio[11532]: pid.c: Daemon already running.
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c: snd_pcm_avail_delay() returned strange values: delay 0 is less than avail 8.
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c: snd_pcm_dump():
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c: Soft volume PCM
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c: Control: PCM Playback Volume
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c: min_dB: -51
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c: max_dB: 0
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c: resolution: 256
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c: Its setup is:
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   stream       : CAPTURE
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   access       : MMAP_INTERLEAVED
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   format       : S16_LE
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   subformat    : STD
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   channels     : 2
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   rate         : 44100
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   exact rate   : 44100 (44100/1)
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   msbits       : 16
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   buffer_size  : 88192
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   period_size  : 44096
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   period_time  : 999909
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   tstamp_mode  : ENABLE
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   period_step  : 1
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   avail_min    : 87310
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   period_event : 0
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   start_threshold  : -1
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   stop_threshold   : 6205960286516543488
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   silence_threshold: 0
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   silence_size : 0
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   boundary     : 6205960286516543488
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c: Slave: Hardware PCM card 0 'HDA Intel' device 0 subdevice 0
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   appl_ptr     : 87320
Jan  8 09:33:21 al-ubuntu pulseaudio[11429]: alsa-util.c:   hw_ptr       : 87320
Jan  8 09:33:22 al-ubuntu kernel: [ 4962.078306] opera[11036]: segfault at 261 ip 0000000000000261 sp 00007fffed7cd9a8 error 14 in opera[400000+122b000]
anjanesh@al-ubuntu:~$
Skype
Jan  8 09:40:21 al-ubuntu pulseaudio[12602]: pid.c: Daemon already running.
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c: snd_pcm_avail_delay() returned strange values: delay 0 is less than avail 8.
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c: snd_pcm_dump():
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c: Soft volume PCM
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c: Control: PCM Playback Volume
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c: min_dB: -51
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c: max_dB: 0
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c: resolution: 256
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c: Its setup is:
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   stream       : CAPTURE
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   access       : MMAP_INTERLEAVED
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   format       : S16_LE
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   subformat    : STD
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   channels     : 2
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   rate         : 44100
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   exact rate   : 44100 (44100/1)
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   msbits       : 16
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   buffer_size  : 88192
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   period_size  : 44096
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   period_time  : 999909
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   tstamp_mode  : ENABLE
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   period_step  : 1
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   avail_min    : 87310
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   period_event : 0
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   start_threshold  : -1
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   stop_threshold   : 6205960286516543488
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   silence_threshold: 0
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   silence_size : 0
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   boundary     : 6205960286516543488
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c: Slave: Hardware PCM card 0 'HDA Intel' device 0 subdevice 0
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   appl_ptr     : 87312
Jan  8 09:40:23 al-ubuntu pulseaudio[12485]: alsa-util.c:   hw_ptr       : 87312
Open Office
Jan  8 09:43:46 al-ubuntu pulseaudio[13157]: pid.c: Daemon already running.
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c: snd_pcm_avail_delay() returned strange values: delay 0 is less than avail 16.
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c: snd_pcm_dump():
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c: Soft volume PCM
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c: Control: PCM Playback Volume
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c: min_dB: -51
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c: max_dB: 0
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c: resolution: 256
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c: Its setup is:
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   stream       : CAPTURE
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   access       : MMAP_INTERLEAVED
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   format       : S16_LE
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   subformat    : STD
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   channels     : 2
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   rate         : 44100
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   exact rate   : 44100 (44100/1)
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   msbits       : 16
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   buffer_size  : 88192
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   period_size  : 44096
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   period_time  : 999909
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   tstamp_mode  : ENABLE
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   period_step  : 1
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   avail_min    : 87310
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   period_event : 0
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   start_threshold  : -1
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   stop_threshold   : 6205960286516543488
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   silence_threshold: 0
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   silence_size : 0
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   boundary     : 6205960286516543488
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c: Slave: Hardware PCM card 0 'HDA Intel' device 0 subdevice 0
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   appl_ptr     : 87320
Jan  8 09:43:48 al-ubuntu pulseaudio[13064]: alsa-util.c:   hw_ptr       : 87320
Thomas Ward
  • 78,878
anjanesh
  • 703
When you are presented with the login screen, it means your X-session crashed. You should investigate your logging, maybe it is a conflict with another package.
I had exactly this situiation on Ubuntu 10.04 x64.
  1. Fresh installation of Ubuntu
  2. Nvidia X-driver through Ubuntu Software Center
  3. Opera and Skype through Ubuntu Software Center
And after that Ubuntu began to log me out right after accepting licension agreement in Skype and Opera.
I went to System->Administration->Update Manager and did a full update, then reboot and everything works ok now!
Kris Harper
  • 13,705
I was able to find the fix for this from a bug report. If you have "xfs" installed (I think it's some kind of xfont server or something), you need to remove it.
Removing that package eliminated the problem completely for me.
RolandiXor
  • 51,797
