Since the pandoc package in the repository is outdated, I would like to install it via cabal-install.
I ran cabal update, and then cabal install pandoc which fails with:
cabal: Couldn't read cabal file "pandoc/1.9.4.4/pandoc.cabal"
This might be relevant:
cabal --version
cabal-install version 0.10.2
using version 1.10.1.0 of the Cabal library
my machine is running oneiric.
jottr
  • 764
Type echo $PATH and you'll probably see something that either (a) does not include $HOME/.cabal/bin or contains $HOME/.cabal/bin near the end.
Type export PATH=$HOME/.cabal/bin:$PATH, and then cabal install cabal-install. This will install the proper version of cabal, since the version in the ubuntu repositories is out-of-date. Then, you can cabal install pandoc just fine.
andrew
  • 31
