I did a fresh install of Ubuntu 12.10 in my Asus X101CH Eee PC, using a live usb which I made using startup disk creator, replacing Ubuntu 12.04. The installation ran smoothly, but when I boot, it goes to a purple screen for a second, then a lot of text like the following shows up in sequence:
Starting crash report submission daemon                        [OK]
Starting CPU interrupts balancing daemon                       [OK]
Stopping save kernel messages                                  [OK]
_
And the cursor just keeps blinking for hours. I can't log in. Pressing Alt + F2 did not bring me to console mode.
I thought it might be a partition problem so I formatted the whole disk, by creating a new partition table using gparted in Ubuntu 12.04 live USB. I noticed that I can't try Ubuntu using 12.10 live USB either; it just went to a blank screen when I hit the 'try ubuntu' button.
But the same problem arose. I even changed the pen drive for the live USB a couple of times.
I happened to know that the Intel Atom N2600 Cedar Trail CPU in my computer is not well supported in Linux, I managed to install its drivers in Ubuntu 12.04, although the computer went blank during the installation.
bain
  • 12,200
Najdmie
  • 61
  1. On boot push F5 (or Tab, it depends on the tool you use to start it) and add to kernel option at the end: "text". In case you already have the "persistent" option you must remove it.
  2. It will boot to a shell with user ubuntu
  3. sudo nano /etc/X11/xorg.conf (it will create this file):
Section "Device"
Identifier "Intel GMA3600"
Driver "fbdev"
EndSection
  1. Save the file
  2. Start the graphical session whith command:sudo service lightdm start
Source - http://linuxeeepc.blogspot.in/2012/08/lubuntu-on-eeepc-1025c-with-correct.html
Matcha
  • 31
The same thing was happening to me and I just fixed it by adding the "nomodeset" parameter. Try this http://ubuntuforums.org/showthread.php?t=1613132.
How to get started Intel Atom N2600 / N2800 netbooks after an upgrade from 12.04 to 12.10:
  1. After starting the machine press immediately the SHIFT button. This will start GRUB - boot options.
  2. Select extended options. Some kernel versions will appear.
  3. Choose a 3.0.2.x version - 3.05.x will cause trouble
  4. The machine will boot.
But: Touchpad, WiFi and external media will not work. You need a USB mouse. To connect to the Internet/network, you will need an Ethernet cable.
At this stage it is possible to wait for an improved kernel. Important data can be sent via network or as an email attachment.
Good luck.
Peachy
  • 7,235
  • 40
  • 47
Chris
