I have installed a few apps from the Terminal by adding repositories and running commands but how do I access them? They aren't in the launcher and I can't see them in the Dash either.
I'm running Ubuntu 12.10.
I ran the following lines of code:
sudo add-apt-repository ppa:yorba/ppa
sudo apt-get update && sudo apt-get install geary
devav2
  • 37,290
mub
It sounds like you've hit a known bug in Geary 0.2.1. For now you can launch Geary as follows:
  1. Press Alt-F2
  2. Type "geary" (all lower case, no quotes)
  3. Press Enter
Keep in mind this is just a temporary workaround; the Geary 0.2.2 package should become available very soon as an update for you and make this unnecessary.
There's a couple of other points I'd like to address about your question:
  • There's no need to add the Yorba PPA in this case, since it doesn't contain a Geary package for your version of Ubuntu. In fact, the default Ubuntu 12.10 repository hosts Geary 0.2.x. If you're interested you can view the Yorba PPA contents here.
  • Terminal commands are generally referred to as "commands" rather than "lines of code." I mention this because it may confuse people (especially us software developers!)
MrEricSir
  • 1,266
You can create a custom dash icon:
How to create custom dash icons?
In your case, you should use:
[Desktop Entry]
Type=Application
Version=1.0
Name=Geary
GenericName=Generic name you want
Comment=Your comments about this file
Exec=geary
Icon=geary
Terminal=false
Categories=Email;Geary;
MimeType=text/plain;text/x-chdr;text/x-csrc;text/x-c++hdr;text/x-c++src;text/x-java;text/x-dsrc;text/x-pascal;text/x-perl;text/x-python;application/x-php;application/x-httpd-php3;application/x-httpd-php4;application/x-httpd-php5;application/xml;text/html;text/css;text/x-sql;text/x-diff;
StartupNotify=true
If you want to launch it from the terminal, just type:
geary &
