Possible Duplicate:
no windows 7 entry in grub after installing ubuntu
i just install Ubuntu 12.10 along side Windows 7.When booting it goes straight to ubuntu and skip grub.This problem occured since 12.04 on 11.10 everything went just fine. I run update-grub and Windows 7 is not listed.
Extra: My partition sda2 is ext4 Ubuntu 12.10 (46gb) sda3 is swap Swap File (4gb) sda5 is ntfs Windows 7 (50gb) sda6 is ntfs Everything (400gb)
Naim
try opening a terminal (either windows-key, type terminal, or ctrl+alt+T) and doing a:
sudo update-grub
fixed it for me...
Failing that, you might need to reinstall Grub completely. There's some instructions here
https://help.ubuntu.com/community/RecoveringUbuntuAfterInstallingWindows
I've used boot-repair in the past, but it looks like it might be as simple as just doing a
sudo grub-install /dev/sda
the important thing is to use the device (sda) not the partition (eg sda6)
hwjp
  • 1,457
