sudo apt-get install g++
Reading package lists... Done
Building dependency tree
 g++ : Depends: g++-4.7 (>= 4.7.0-1~) but it is not going to be installed
Jorge Castro
  • 73,717
Ullen
Seems like you have some broken packages or dependencies. Try doing sudo apt-get update, if you get some error updating, try following:
sudo apt-get clean
cd /var/lib/apt
sudo mv lists lists.backup
sudo mkdir -p lists/partial
sudo apt-get clean
sudo apt-get update
and then try installing g++.
jokerdino
  • 41,732
Always run sudo apt-get update then sudo apt-get install g++. The sudo apt-get clean command is optional. My install worked just fine without it.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Rather than just installing g++ or gcc it is more recommended to install the build-essential package.
You should install it with the following commands:
sudo apt-get update
sudo apt-get install build-essential
Those two commands should install all the basics needed by the system to build things.
Thomas Ward
  • 78,878
