13
How to write Bash script to open a terminal with two tabs, and execute commands in both tabs?
for instance:
tab 1 opens skype
tab 2 opens chromium-browser
In the end, I want one more thing: write a bash script with my skype username and password and feed those to skype.
Thanks
Ahmed Zain El Dein
  • 634
  • 25
one terminal with two tabs:
gnome-terminal --tab --tab
use the -e switch to execute commands (or scripts):
gnome-terminal --tab -e "command1" --tab -e "command2"
(I don't think there is an easy way of feeding your credentials to skype via the terminal.)
Update: check w4YGcbTeIH's answer, skype allows giving credentials via the command line.
But beware, your credentials would be exposed and this should be avoided.
A script to open skype and chromium-browser would look like the following:
#!/bin/bash
skype --dbpath=<path> &
chromium-browser &
Put this code into myscript.sh and execute chmod +x myscript.sh (in a terminal) to make it executable.
About skype:
  • you can run skype without arguments (skype &) and it will load your default user profile ~/.Skype.
  • run it with --dbpath=<path> where <path> is your actual path of the Skype profile you want skype to load.
To run the script do one of the following:
  • open a terminal and execute ./myscript.sh
  • double click on the script and choose Run in the dialog.
rosch
  • 8,168
$ skype -h
Skype 4.0.0.8
Usage: skype [options]
Options:
  --dbpath=<path>       Specify an alternative path to store Skype data files.
                        Default: ~/.Skype
  --resources=<path>    Specify a path where Skype can find its resource files.
                        Default: /usr/share/skype
  --disable-api         Disable Skype Public API.
  --callto <nick>
  skype:<nick>?<action>
                        These commands allow Skype links handling.
  --pipelogin           Command line login. "echo username password | skype --pipelogin"
  --version             Display version information and exit.
echo username password | skype --pipelogin does what you want, but as rosch said : "Also, your credentials would be exposed and this should be avoided." They would be exposed on the history of the shell :
$ echo user pass | skype --pipelogin
$ history
 2006  echo user pass | skype --pipelogin
 2007  history
