I have this folder that contains many folders, each containing many files with the name structure .XYZ.zip.
I'd like to rename them (using bash) to XYZ.zip (i.e. un-hide them).
I've seen a question attempting to do a similar thing,
alias deannoy='for annoyingbak in *.bak;do mv "$annoyingbak" ."$annoyingbak";done'>> ~/.bashrc && . .bashrc
but I've not been able to manage to change so it's done recursively for all folders down from the current folder.
user2413
  • 14,957
There is a good answer on sister-site stackoverflow: It says:
#!/bin/bash
recurse() {
 for i in "$1"/*;do
    if [ -d "$i" ];then
        echo "dir: $i"
        recurse "$i"
    elif [ -f "$i" ]; then
        echo "file: $i"
    fi
 done
recurse /path
OR if you have bash 4.0
#!/bin/bash
shopt -s globstar
for file in /path/**
do
    echo $file
done
Say thank you over at stackexchange to ghostdog74 if this works for you. The askubuntu account will work there too.
turbo
  • 4,712
The for ... in *.bak command searches only the current directory.
You want instead to use the find command, which searches recursively. This command will locate all zip files starting with a dot at any depth in the current directory (.).
find . -iname '.*.zip'
Removing the leading dot is a bit trickier though. The following seems to work (but may have edge cases, caveat emptor).
for f in $(find -iname '.*.zip'); do f2=$(echo $f | sed -re 's/(.*)\/\.(.*)/\1\/\2/'); echo $f $f2; done
This will print all the operations it would perform (echo $f $f2), if this list looks right change it to mv $f $f2 and it will do the renames.
chronitis
  • 12,647
You can use this command:
$ find foobar/ -type f -iname ".*" -exec rename -n 's/^(.+)\/\.(.+)$/$1\/$2/' '{}' \;
foobar/sub_dir/moresubdir/.foo bar.zip renamed as foobar/sub_dir/moresubdir/foo bar.zip
foobar/sub_dir/moresubdir/.one.zip renamed as foobar/sub_dir/moresubdir/one.zip
foobar/sub_dir/moresubdir/.two.zip renamed as foobar/sub_dir/moresubdir/two.zip
foobar/sub_dir/.one.zip renamed as foobar/sub_dir/one.zip
foobar/sub_dir/.two.zip renamed as foobar/sub_dir/two.zip
foobar/.foo bar.zip renamed as foobar/foo bar.zip
foobar/.one.zip renamed as foobar/one.zip
foobar/.two.zip renamed as foobar/two.zip
find will recursively search for all hidden files then pass them to rename. The -n param causes rename to dry-run the substitution rule to show you what those files would be renamed to. If you're happy with the results, remove the param so it renames the files for real
Flint
  • 3,201
