Changes in window themes of something of the sort is causing the popup dialogs in Eclipse to have a very dark background. Then, since Eclipse uses hyperlinks in dialogs, I get blue on black, and it's basically unreadable. I tried changing themes in Ubuntu Tweak, but nothing seemed to affect the background color of that dialog. Can anyone help?
What I'm looking at: https://i.sstatic.net/319mj.jpg
Eclipse can use GTK themes but it is an option, it's not obligatory. Go to Preferences, General->Appearence. Select "Classic" in Theme instead of GTK. Restart eclipse and you should be happy with the result.
Cheers :)
I use Kubuntu 12.10.
I fix this problem with change color of tooltips background and change color of text tooltips.
On ubuntu 12.10 (quantal) you can use the following two commands:
#foreground white => black
sudo sed -i s/tooltip_fg_color:#ffffff/tooltip_fg_color:#000000/g  /usr/share/themes/Ambiance/gtk-3.0/settings.ini /usr/share/themes/Ambiance/gtk-3.0/gtk.css /usr/share/themes/Ambiance/gtk-2.0/gtkrc
#background black => yellow
sudo sed -i s/tooltip_bg_color:#000000/tooltip_bg_color:#f5f5b5/g  /usr/share/themes/Ambiance/gtk-3.0/settings.ini /usr/share/themes/Ambiance/gtk-3.0/gtk.css /usr/share/themes/Ambiance/gtk-2.0/gtkrc
(Thanks to the other answers here that helped me to figure this out)
AmanicA
  • 1,887
