I've upgraded to Ubuntu 12.10 and now I can't mount any partition. I get the same error with all drives:
/usb: Adding read ACL for uid 1000 to /media/evil' failed: Operation not supported
Both of my USB drives are FAT32, one is a USB stick, the other is a GOPRO cam and both were working fine in 12.04.
Eliah Kagan
  • 119,640
It is bad advice to use permission 777 on anything. Any user on the system gets read/write access to your files.
sudo mkdir /media/${USER}
sudo chown ${USER}.${USER} /media/${USER}
chmod 750 /media/${USER}
Konstigt
  • 370
In my case after upgraded to UBUNTU 12.10 my username in /media didn't exist, so I created it and problem SOLVED!
Also you can try to mount those drives manually, using terminal:
mount -t devicefilesystem /dev/something /media/something
for example mount -t ntfs /dev/sda2 /media/windows but before doing this, you have to create directory windows (or other, it's up to you) in /media like this mkdir /media/windows. This helped me.
Quick and Dirty method:
I have same problem and it seemed I solved by changing user owner and group owner of the directory: /media/<your username>
In command line type
sudo mkdir -p /media/<your username>
sudo chmod 777 /media/<your username>
sudo chown <username> /media/<your username>
Pluck out usb device put it back in and it should start working
Marco Ceppi
  • 48,827
