My DSL internet did not connect by network-manager! So I tried to use sudo pppoeconf and my laptop connect to internet successfully. After that my problems are started! First of all network-manager does not run in start up! I try sudo nm-applet and get
** (nm-applet:4966): WARNING **: Could not initialize NMClient /org/freedesktop/NetworkManager: The name org.freedesktop.NetworkManager was not provided by any .service files
** Message: applet now removed from the notification area
** (nm-applet:4966): WARNING **: Failed to register as an agent: (2) The name org.freedesktop.NetworkManager was not provided by any .service files
** Message: using fallback from indicator to GtkStatusIcon
** Message: Starting applet secret agent because GNOME Shell disappeared
and I try sudo /etc/init.d/networking start, which I gain
Rather than invoking init scripts through /etc/init.d, use the service(8) utility, e.g. service networking start
Since the script you are attempting to invoke has been converted to an Upstart job, you may also use the start(8) utility, e.g. start networking
any after I try service networking start
start: Rejected send message, 1 matched rules; type="method_call", sender=":1.71" (uid=1000 pid=3624 comm="start networking ") interface="com.ubuntu.Upstart0_6.Job" member="Start" error name="(unset)" requested_reply="0" destination="com.ubuntu.Upstart" (uid=0 pid=1 comm="/sbin/init")
This is my /etc/ppp/peers/dsl-provider
noipdefault
usepeerdns
hide-password
lcp-echo-interval 20
lcp-echo-failure 3
connect /bin/true
noauth
persist
mtu 1485
noaccomp
default-asyncmap
plugin rp-pppoe.so eth0
user "511"
This is my /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
# manual
auto dsl-provider
iface dsl-provider inet ppp
provider dsl-provider
and this is my /etc/NetworkManager/NetworkManager.conf
[main]
plugins=ifupdown,keyfile
dns=dnsmasq
[ifupdown]
managed=false
The problem is to reverse this process! And bring back nm-applet to my desktop again!
I need NetworkManager to share my DSL internet through my modem.
So I have two question: First, Is there any way that I can reconfigure my network like before running sudo pppoeconf? Second, if there is not any way to bring NetworkManager to my desktop, how can I share my internet without NetworkManager?
Thanks in advance
