Situation: an application freezes the X server and no keyboard input works. So I use Alt+SysRq+R to take the keyboard out of raw mode (make the kernel take control of the keyboard away from the X server). I can then type Ctrl+Alt+F1, kill the bad processes, and everything works again. So far so good.
But the keyboard is still in the hands of the kernel, making Alt+Left/Right shortcuts for Decr_Console/Incr_Console. This is annoying, and I want to give control over the keyboard back to the X server.
I have tried typing Alt+SysRq+R again, this does not switch things back. I have also tried the command kbd_mode -u, but nothing changes.
Any advice?
NorTicUs
  • 2,402
  • 20
  • 34
sudo kbd_mode -s -C /dev/tty7
Eventually you have to change the console path, if your X server is running on a different virtual terminal.
Source: https://unix.stackexchange.com/questions/19296/recovering-from-sys-rq-r
