I'm using a special program that has only .rpm version available as installer. As I need to run it on Ubuntu, Is there a way to install it in Ubuntu?
Asked
Active
Viewed 1.5k times
Which program is it? You can always try and convert it using alien in command line.
With alien you can convert from/to rpm/deb/tgz/slp.
The process is pretty straightforward:
sudo alien myfile.rpm
I think it will also attempt to install it.
If you don't have Alien installed, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command below.
sudo apt-get install alien
Mitch
- 109,787
Savvas Radevic
- 7,821
