32
I just moved from RH/Fedora to Ubuntu 12.04. In RedHat, when I reopen a file with VIM, it opens with the cursor on the line it was on when I closed the file. However, what I am seeing now is that when I reopen a file, the cursor is always at the top, every time. As some of the files I am working with are 20k lines long, this gets a bit old quickly.
I installed the full version of VIM via apt-get on my new Ubuntu so that I could use the arrow keys in insert mode. The version that is printed out is VIM - Vi IMproved 7.3.
Any help at all would be gratefully welcomed.
lambda23
  • 3,362
pennyrave
  • 453
Add the following lines to your ~/.vimrc or global /etc/vim/vimrc
if has("autocmd")
  au BufReadPost * if line("'\"") > 0 && line("'\"") <= line("$") | exe "normal! g`\"" | endif
endif
This will jump to the last known cursor position unless:
  • the position is invalid
  • the position is inside an event handler
Sentry
  • 739
11
Your system probably already contains the necessary feature. You just need to uncomment it in the default configuration /etc/vim/vimrc or add it to your ~/.vimrc file. vim is not remembering last position
" Uncomment the following to have Vim jump to the last position when
" reopening a file
if has("autocmd")
  au BufReadPost * if line("'\"") > 1 && line("'\"") <= line("$") | exe "normal! g'\"" | endif
endif
This is an auto command that looks for line numbers of the evaluated expressions. The g command jumps to the last position if it was recorded. Using :help on commands BufReadPost, line() and g` will explain the details of how this works.
grantbow
  • 838
