Possible Duplicate:
Can’t boot without Flash Drive plugged in
Installed ubuntu with USB boot, but when I restarted, the laptop was unable to detect it on he HDD. When I boot from the USB everything works as it should though (it's not the pre-installation screen), but I installed it on the HDD. Anyone?
Rosa
Probably you installed GRUB on the pendrive instead of on the hard disk.
Boot through your USB drive, open a terminal (CTRL + ALT + T) and type ls -l /dev/disk/by-label/. You'll get a list of drives of the sort /sda1 /sda2 or /sdb1 etc.
Identify the hard disk where Ubuntu is installed. If it is say sda4, in the terminal type: sudo grub-install /dev/sda without the final number.
Shutdown, remove the pendrive and turn on again.
To Do
  • 15,833
I agree with To Do. It sounds like something is up with your GRUB.
This help page is about recovering GRUB after windows install but should be useful in correctly installing the GRUB in any situation: https://help.ubuntu.com/community/RecoveringUbuntuAfterInstallingWindows
Hope this helps. Take care.
JasperKov
  • 93
  • 14
