I am trying to install ejabberd 2.1.10-2 on my Ubuntu 12.04.1 server. This is a fresh install, and ejabberd is never successfully installed.
The Install
Every time, apt-get hangs on this:
Setting up ejabberd (2.1.10-2ubuntu1) ...
Generating SSL certificate /etc/ejabberd/ejabberd.pem...
Creating config file /etc/ejabberd/ejabberd.cfg with new version
Starting jabber server: ejabberd............................................................ failed.
The dots just go forever until it times out or I 'killall' beam, beam.smp, epmd, and ejabberd processes. I've turned off all firewall restrictions.
Here's the output of epmd -names while the install is hung:
epmd: up and running on port 4369 with data:
name ejabberdctl at port 42108
name ejabberd at port 39621
And after it fails:
At the same time (during and after), the output of both netstat -atnp | grep 5222 and netstat -atnp | grep 5280 is empty.
The Crash File
A crash dump file is create at /var/log/ejabber/erl_crash.dump. The slogan (i.e. reason for the crash) is:
Slogan: Kernel pid terminated (application_controller) ({application_start_failure,kernel,{shutdown,{kernel,start,[normal,[]]}}})
It's alive?
Whenever I try to relaunch ejabberd with service ejabberd start, the same thing happens - even if I've killed all processes before doing so.
However, when I killall the processes listed above again, and run su - ejabberd -c /usr/sbin/ejabberd, this is the output I get:
Erlang R14B04 (erts-5.8.5) [source] [64-bit] [rq:1] [async-threads:0] [kernel-poll:false]
Eshell V5.8.5  (abort with ^G)
(ejabberd@ns1)1>
=INFO REPORT==== 15-Oct-2012::12:26:13 ===
I(<0.478.0>:ejabberd_listener:166) : Reusing listening port for 5222
I(<0.479.0>:ejabberd_listener:166) : Reusing listening port for 5269
I(<0.480.0>:ejabberd_listener:166) : Reusing listening port for 5280
I(<0.40.0>:ejabberd_app:72) : ejabberd 2.1.10 is started in the node ejabberd@ns1
Then, the server appears to be running. I get a login prompt when I access http://mydomain.com:5280/admin/. Of course I can't login unless I create an account.
At this time, the output of netstat -atnp | grep 5222 and netstat -atnp | grep 5280 is as follows:
tcp        0      0 0.0.0.0:5222            0.0.0.0:*               LISTEN      19347/beam
tcp        0      0 0.0.0.0:5280            0.0.0.0:*               LISTEN      19347/beam
ejabberdctl
Even when it appears ejabberd is running, trying to do anything with ejabberdctl fails. For example: trying to register a user:
root@ns1:~# ejabberdctl register myusername mydomain.com mypassword
Failed RPC connection to the node ejabberd@ns1: nodedown
I have no idea what I'm doing wrong. This happens on two different servers I have with identical software installed (really not much of anything). Please help. Thanks.
Seth
  • 59,332
I had this problem one time when the daemon could not determine the ip address of the hostname I gave in the ejabber config file. My solution was to edit /etc/hosts file and make sure that there was a hostname entry for my public ip address and the domain I wanted ejabber to respond to.
0.0.0.0 hostname.domain.com hostname
1.1.1.1 ns1.yahoo.com ns1
Well, you get the picture. Hope that helps.
This is apparmor issue with no access from ejabberd socket (erlang sub-process of notify systemd) -> systemd WATCHDOG. Easiest is to disable apparmor profile with:
ln -s /etc/apparmor.d/usr.sbin.ejabberdctl /etc/apparmor.d/disable/ apparmor_parser -R /etc/apparmor.d/usr.sbin.ejabberdctl
for now.
