@me:/home$ sudo apt-get install polipo
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
polipo
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 198 kB of archives.
After this operation, 799 kB of additional disk space will be used.
Get:1 http://sy.archive.ubuntu.com/ubuntu/ precise/universe polipo amd64
1.0.4.1-1.1 [198 kB]
    Fetched 198 kB in 2s (97.5 kB/s)
    Selecting previously unselected package polipo.
    (Reading database ... 169595 files and directories currently installed.)
Unpacking polipo (from .../polipo_1.0.4.1-1.1_amd64.deb) ...
Processing triggers for doc-base ...
Processing 1 added doc-base file...
Processing triggers for man-db ...
Processing triggers for install-info ...
Processing triggers for ureadahead ...
Setting up polipo (1.0.4.1-1.1) ...
Starting polipo: Couldn't open config file /etc/polipo/config: 2.
invoke-rc.d: initscript polipo, action "start" failed.
****dpkg: error processing polipo (--configure):
subprocess installed post-installation script returned error exit status 1
polipo
E: Sub-process /usr/bin/dpkg returned an error code (1)****
Mark Paskal
  • 2,890
ICXC
  • 101
I get the error because I uninstall polipo and rm the config file in /etc/polipo/.
I fix it follow:
just run commands step by step:
sudo dpkg --configure -a
sudo apt-get install -f
sudo apt update
sudo apt upgrade
refer: https://itsfoss.com/dpkg-returned-an-error-code-1/
liquan.eth
  • 131
The problem might with your config file. I would recommend you to back the original config file /etc/polipo/config and download the config file provided by torbrowser.
Here is the steps
sudo mv /etc/polipo/config /etc/polipo/config.orig
sudo wget https://gitweb.torproject.org/torbrowser.git/blob/ae4aa49ad9100a50eec049d0a419fac63a84d874:/build-scripts/config/polipo.conf \
-O /etc/polipo/config
Now try to rerun the command
Hope this helps
devav2
  • 37,290
