17
I have just bought a shiny new Canon MG6250 multifunction printer/scanner and connected it via LAN. Installing the printing side of things was a breeze, however, I cannot work out how to set up scanning.
I installed the MG6200 series ScanGear MP driver from Canon's site but when I open GIMP or Simple Scan, they say there is no scanner detected. Using GIMP's 'update scanner list' button to search for the scanner does not find it.
How do I tell Ubuntu, GIMP or Simple Scan to look on the network for the scanner? Is there another utility especially for this?
Andrew
  • 644
Just got this going today. This is how I got it working over wireless network, running Xubuntu 12.10 64-bit. (No Canon drivers were needed).
After installing xsane:
  • The sane man pages refer to "backendname" a lot. http://www.sane-project.org/sane-mfgs.html gives the backend name for the 6250 as "pixma"
  • man sane-pixma (seems to be a man entry for each backend) tells you that network scanners should normally be detected, but if not, add them directly to /etc/sane.d/pixma.conf
  • Edit that file and add a line of the format:
    bjnp://<ip_address>
  • IP address can be retrieved from the printer settings, or from the options in the printer itself.
  • After adding an entry for the printer, save pixma.conf
  • Now edit /etc/default/saned and set RUN=yes
  • Then: service saned start
  • Run xsane
Now xsane should discover the scanner, and instead of saying "no devices found" and dying, it should run up (brings up about 4 windows). All the default settings seem to work — just press "Scan".
Ash
  • 941
I have an epson printer/scanner and had to add the IP address to /etc/sane.d/epson2.conf like this:
net 10.0.5.125
I also commented out the net autodiscovery line.
deltaray
  • 235
I found that adding the subnet IP addresses to this file worked when nothing else did: /etc/sane.d/saned.conf
To get the subnet, look at your output from the ifconfig command. Find a line that looks like this: inet addr:192.168.1.4 Bcast:192.168.1.255 Mask:255.255.255.0
From this output, I learned that my wireless router subnet is 192.168.1, and then searched for the printer (wireless router and printer must be powered on and operating) using this command: sudo nmap -sP 192.168.1.0/24
Nmap scan report for 192.168.1.6 Host is up (0.011s latency). MAC Address: XX:Xx:XX:XX:XX:XX (Canon)
From above, 192.168.1.6 is the IP address for my Canon printer/scanner on my LAN.
Therefore, I added this entry to /etc/sane.d/saned.conf: 192.168.1.0/24
xsane could then see my scanner.
Ricky
