The package ttf-mscorefonts-installer is showing up in Update Manager as having been downloaded but not installed. When I run sudo apt-get remove ttf-mscorefonts-installer I get the message
 dpkg: warning: there's no installed package matching ttf-mscorefonts-installer:amd64
I can't uncheck the box next to ttf-mscorefonts-installer in the Update Manager interface, and I can't install any other updates because I get the error message
Requires installation of untrusted packages
The action would require the installation of packages from not authenticated sources.
How do I get rid of ttf-mscorefonts-installer so that it stops causing problems?
Adina G
  • 351
First trying this ->
sudo apt-get update
sudo apt-get -f install
If it doesn't fix the problem, try removing the package with
sudo dpkg -r ttf-mscorefonts-installer
Hope it will help.
Anwar
  • 77,855
Try
sudo apt-get remove --purge ttf-mscorefonts-installer
EDIT: remove --purge is equivalent to the purge command which removes configuration files along with the package.
More info is available here
Elder Geek
  • 36,752
Axx
  • 145
I had the same problem, ttf-mscorefonts-installer stuck in half-installed state.
I was able to remove it using dpkg with the option --force-all:
sudo dpkg --remove --force-all ttf-mscorefonts-installer
And then dpkg --purge:
sudo dpkg --purge --force-all ttf-mscorefonts-installer
