Sorry for the long question, but the situation/desire is quite complex. Here is my setup: I have a laptop which I carry around everywhere and I have a desktop sitting at home, connected to the internet through a router using NAT.
My objective is to create a connection from my laptop to my desktop that can allow me to (in order of priority):
  1. Use the desktop as a proxy server
  2. Access files on the desktop remotely
  3. Control said desktop from the laptop using VNC or similar.
Now here is the scene. I have already looked up and tried several ways to achieve the above goals.
  1. Teamviewer - I used it and didn't like it. This is not an option.
  2. SSH - This seems ideal, I have figured a way to use this for both proxy and file sharing. However, I am currently unable to connect it due to the NAT. I have a separate thread trying to get that to work here.
  3. VPN - I've figured out how to use this method for proxy, but not file sharing. However this faces the same problem as the above: I can't get it to connect through the NAT.
Does anyone have any other solutions for what I want? Otherwise, if there are solutions to connecting through the NAT, please tell me (in the other thread).
Thanks
You can configure using Squid proxy server and Dansguardian content filtering combination The following is the link and the steps
http://kamleshgosavi.blogspot.in/2011/01/dansguardian-content-filtering-with.html
Dansguardian Content Filtering With Squid Transparent Proxy On Ubuntu Dansguardian Content Filtering With Squid Transparent Proxy On Ubuntu
sudo apt-get install squid3 sudo nano /etc/squid3/squid.conf
(Search for http_port 3128 and add following ) http_port 3128 transparent
(Search for INSERT and add following )
acl localnet src 192.168.2.0/24
http_access allow localnet http_access allow localhost
sudo /etc/init.d/squid3 restart For squid in detail follow the below link dont follow the IPtable part from this link
kam gos
  • 106
