It turns out there is:
Playing Youtube playlists using a playlist parser script for VLC
Installation
Instructions as per the source:
- download the script (or copy it and paste it in a new file with the
name
playlist_youtube.lua)
- move the file to
~/.local/share/vlc/lua/playlist/ (current user) or
/usr/share/vlc/lua/playlist/ (all users)
Usage
Open up VLC and hit CTRL+N to display the Open
Network Stream dialog. Paste your youtube playlist link into the text field
and hit Enter. Make sure the link you copied contains the youtube playlist identifier (list=PLxxx).
Note: This script relies on VLC's inbuilt youtube parser. As youtube
changes its system now and then, video playback in VLC might suddenly stop
working. In that case you will have to update your youtube parser script.
You can do so with the following commands (credit goes to phoibos):
sudo apt-get install curl
(makes sure curl is installed)
sudo rm /usr/lib/vlc/lua/playlist/youtube.*
(removes old parser)
sudo curl "http://git.videolan.org/p=vlc.git;a=blob_plain;f=share/lua/playlist/youtube.lua;hb=HEAD" -o /usr/lib/vlc/lua/playlist/youtube.lua
(downloads new parser)
