-1
Possible Duplicate:
Cannot install shell-themes using gnome-tweak-tool
This is my fifth full format and install of Ubuntu in under a month. I finally have my Gnome 3 desktop working again, but again, the Gnome shell themes is not select-able. I have asked the question of how to fix this common issue before, but I have seen no positive resolution. Does anybody know of a simple fix? This is a common issue and I have seen hundreds of postings related to it, but other users only seem to get half-way answers also and it goes unresolved. Would it be advisable to completely purge Gnome desktop and reinstall? If so how would I do this? I cannot use any extensions if the shell is not working, so I am desperately seeking resolution for the issue. Thanks in advance.
Chris
  • 19
Have you tried reinstalling gnome desktop with
sudo apt-get purge gnome-desktop&&sudo apt-get install gnome-desktop
nanofarad
  • 20,906
All gnome shell extensions are here : Gnome Shell Extensions.
You must have an active gnome-shell environment and the gnome-tweak-tool installed. Goto the page and click the "About" and you will see how you can install them. On the search bar you can search for any theme you want. Example : User themes
The installation is very easy , just click the light button. You will figure it out.
NickTux
  • 17,865
  • 57
  • 66
