root@deepak:~# eclipse
** (eclipse:28003): WARNING **: The connection is closed
find: `/root/.eclipse': No such file or directory
W: Cannot inject update-sites, cannot find the correct config.
** (eclipse:28002): WARNING **: The connection is closed
** (Eclipse:28002): WARNING **: The connection is closed
similar when i try to logged in User then
/home/deepak/.eclipse/org.eclipse.platform_3.7.0_155965261/configuration/1350065308917.log.
log message
!SESSION 2013-10-12 23:38:28.737 -----------------------------------------------
eclipse.buildId=I20110613-1736
java.version=1.7.0_07
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_IN
Command-line arguments:  -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 4 0 2012-10-12 23:38:31.851
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
        no swt-gtk-3740 in java.library.path
        no swt-gtk in java.library.path
        Can't load library: /home/deepak/.swt/lib/linux/x86/libswt-gtk-3740.so
        Can't load library: /home/deepak/.swt/lib/linux/x86/libswt-gtk.so
        at org.eclipse.swt.internal.Library.loadLibrary(Library.java:285)
        at org.eclipse.swt.internal.Library.loadLibrary(Library.java:194)
        at org.eclipse.swt.internal.C.<clinit>(C.java:21)
        at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java:63)
        at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java:54)
        at org.eclipse.swt.widgets.Display.<clinit>(Display.java:132)
        at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:695)
        at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
        at org.eclipse.ui.internal.ide.application.IDEApplication.createDisplay(IDEApplication.java:153)
        at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:95)
        at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:601)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
devav2
  • 37,290
Deepak
  • 29
Looks like you are missing some java libraries from the error messages. Try:
sudo apt-get install libswt-gtk-3-jni libswt-gtk-3-java
I think those are the correct packages, but when you see error messages like Unsatistified dependency this means you are missing something the program needs to work. So you need to find the package that has that dependency and add it to your computer.
