Is there a workspace switcher for Compiz like elementary's? It's faster and nicer than Ubuntu's current one. Alternatively, is it possible to use elementary's window manager instead of Compiz?
Asked
Active
Viewed 4,144 times
I can answer one of your questions
sudo add-apt-repository ppa:elementary-os/daily
sudo apt-get update
sudo apt-get install gala
gala --repĺace
That will install gala the elementary window manager.
Goddard
- 4,860
Typically workspace switchers are integrated in window manager. So, I don't believe you can use separate workspace switcher in compiz. I don't know of any workspace switcher independent of window manager
No. Elementary uses gala window manager. But if you try to use it, it will kill compiz (which in turn will kill Unity) because two window managers can't run simultaneously.
Anwar
- 77,855
I had problems trying to install in Ubuntu 14.04
There was an error with libmutter0d that was solved by running
sudo apt-add-repository ppa:elementary-os/testing
sudo apt-get update
Now the right version of libmutter0d is installed
Zanna
- 72,312
Marcos Jacoby
- 586
