I was tring to install eclipse on ubuntu. What I did: I unzipped the tar archive of eclipse. I tried to start eclipse from the command line - like this - ./eclipse. It works. But then I tried to create a desktop icon with: gnome-desktop-item-edit ~/Desktop --create-new. In a new icon I showed the path to the eclipse executable which I could launch from the command line. But then eclipse does not start stating:
A Java Runtime Environment (JRE) or Java Development Kit (JDK)
must be available in order to run Eclipse. No Java virtual machine
was found after searching the following locations:
/home/artem/eclipse/jre/bin/java
java in your current PATH
The same message appears if I try to launch eclipse by double-clicking its original launcher. So it starts from the terminal but not from the desktop (it does not start when double-clicked) And also I get a message in the terminal (at some stage it appeared):
(gnome-desktop-item-edit:8998): Gtk-WARNING **: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file '/root/.local/share/recently-used.xbel.DSV8LW': No such file or directory
I am using Ubuntu 12.04 x32 and eclipse Juno.
PS. PATH variable points at jdk/bin and JAVA_HOME - to the jdk folder PSS. I actually set the environment variables through .bashrc file(JAVA_HOME and PATH)
