When I try to install libapache2-mod-php5, I get an error:
The following information may help resolve the situation:
 libapache2-mod-php5 : Depends: apache2-mpm-prefork (> 2.0.52) but it is not going to be installed or
                                apache2-mpm-itk but it is not going to be installed
I have tried apt-get clean, update and upgrade, as well as -f install, and no change.
Is there a way to fix this, or is there an easy way to manually install the php plugin?
chris
  • 315
How did you install apache - From the repository or from Apache's website, or compiled?
Normally, it would install apache2-mpm-prefork for the traditional non-threaded model; apache2-mpm-itk is the multiuser MPM. Both can be installed from the repository, and the prefork is normally installed with the apache2 metapackage. It seems like reinstalling apache2 should do it, or simply installing the missing package directly, although if you're missing one, you may be missing others.
Manually installing the php plugin it is not a solution - it depends on one of these packages, so would not be expected to run correctly without it. That's what a dependency is.
Marty Fried
  • 18,944
Are you on on a system that has moved to php7? check out this answer if yes: Can't install php5 on Ubuntu 16.04
Aaron
  • 161
