I installed tomcat servlet but I need to autostart it on boot. How to do that?
Zanna
  • 72,312
You need to create an init script for tomcat and add it to the correct runlevel init script.
Advice adapted from here http://www.raibledesigns.com/tomcat/boot-howto.html
Create an init script /etc/init.d/tomcat/ for tomcat, changing the value for catalina home to the correct location:
#!/bin/bash
# tomcat
# chkconfig:
# description:  Start up the Tomcat servlet engine.
# Source function library.
. /etc/init.d/functions
RETVAL=$?
CATALINA_HOME="/usr/apps/apache/tomcat/jakarta-tomcat-4.0.4"
case "$1" in
 start)
        if [ -f $CATALINA_HOME/bin/startup.sh ];
          then
        echo $"Starting Tomcat"
            /bin/su tomcat $CATALINA_HOME/bin/startup.sh
        fi
 stop)
        if [ -f $CATALINA_HOME/bin/shutdown.sh ];
          then
        echo $"Stopping Tomcat"
            /bin/su tomcat $CATALINA_HOME/bin/shutdown.sh
        fi
    echo $"Usage: $0 {start|stop}"
    exit 1
esac
exit $RETVAL
Then add a link to the rc5.d folder - /etc/rc5.d/
sudo ln -s /etc/init.d/tomcat /etc/rc5.d/S71tomcat
penreturns
  • 5,950
One way to start the tomcat on the startup is to run it using cron using the @reboot attribute:
open up a terminal and type :
sudo crontab -e
at the end of the file enter the command:
@reboot /`PATH_TO_WHERE_TOMCAT_INSTALLED`/bin/startup.sh
save the file and exit.
The above command will run the command once everytime computer boots up.
Sobhan
  • 111
