Is it possible to get the latest Unity without upgrading to 12.10 on my Ubuntu 12.04 PC or will this be backported?
This Works:
Open Terminal, then type
sudo add-apt-repository ppa:benkai/precise-unity-backport
sudo apt-get update
sudo apt-get remove unity-lens-applications
sudo apt-get install unity
wget http://ppa.launchpad.net/benkai/precise-unity-backport/ubuntu/pool/main/u/unity-lens-applications/unity-lens-applications_6.4.0-0ubuntu2_i386.deb
sudo dpkg -i unity-lens-applications_6.4.0-0ubuntu2_i386.deb
From: https://launchpad.net/~benkai/+archive/precise-unity-backport
- 61
An official backport won't happen, no.
Because Unity 6.0 depends on the latest Quantal versions of Nux and Compiz, which in turn depend on the newer versions of other libraries, like libunity-webapps, indicators, etc. Unity 5.x, however, will continue to be supported for the entire life cycle of Ubuntu 12.04 with stable release upgrades to fix bugs.
It would be possible for a community developer to take the source code of Unity 6.0 and dependent libraries, try building it with Precise libraries (many modifications would be needed) and put it up in a PPA, but it won't be worth the effort.
- 2,998
Yes, you can get the latest version and build it manually, I haven't tried this, but some people succeeded on doing it:
How do I build Unity from source?
Since it contains only some bug fixes, It's not that great updating it to version 6.
- 9,922
I tried to give it a Google and found this link referring to Unity backporting from Quantal to Precise which may be of some use to you.
- 1,917
- 11
It all depends on dependencies, really. If the dependencies for 6.2 can be satisfied, then it is likely it will be backported to Ubuntu 12.04 in the near future.
- 51,797
