22
I've been looking at other questions, but none seem to answer my query. The closest I got gave me information about a ppa for 12.04. My computer's battery life is suffering under Ubuntu 12.10. I imagine the performance will be better if I use LLVMPipe, as it is aimed at lower end computers. How do I enable LLVMPipe?
I might add that going back to 12.04 is not an option, as my computer only works in Unity 2D, which didn't quite do it for me. As far as I understand, LLVMPipe is pretty much the same as regular Unity. However, I can't seem to find much information about it. If this is wrong, correction would be much appreciated.
mniess
  • 10,904
Mr Greeb
  • 273
There is an environment variable you can set, UNITY_LOW_GFX_MODE
Running
UNITY_LOW_GFX_MODE=1 unity
should replace your existing session with the "low graphics mode" desktop.
If for some reason you want to make it permanent
  • For your user:
    Add the line
      export UNITY_LOW_GFX_MODE=1
    to the file ~/.xprofile (create one, if it doesn't exist).
  • Or globally:
    Create a file /etc/X11/Xsession.d/99force-llvm and add above line (requires root permissions, see this answer about how to create a file as root).
    You can set this globally in one step by running the following line inside a terminal:
      echo "export UNITY_LOW_GFX_MODE=1" | sudo tee /etc/X11/Xsession.d/99force-llvm
Jorge Castro
  • 73,717
