I have been using Apache2 and Webmin with my Raspberry Pi. After a restart and reinstallations Apache won't start.
> sudo /etc/init.d/apache2 restart
apache2: Syntax error on line 268 of /etc/apache2/apache2.conf: Could not open configuration file /etc/apache2/sites-enabled/000-default: No such file or directory
Action 'configtest' failed.
The Apache error log may have more information.
failed!
The file 000-default is there and unopenable permissions to root-root. My apache2.conf file looks like this (bottom half):
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog ${APACHE_LOG_DIR}/error.log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel debug
# Include module configuration:
Include mods-enabled/*.load
Include mods-enabled/*.conf
# Include list of ports to listen on and which to use for name based vhosts
Include ports.conf
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
# If you are behind a reverse proxy, you might want to change %h into %{X-Forwarded-For}i
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Include of directories ignores editors' and dpkg's backup files,
# see the comments above for details.
# Include generic snippets of statements
Include conf.d/
# Include the virtual host configurations:
Include sites-enabled/
<VirtualHost *:80>
DocumentRoot /var/www
<Directory /var/www>
allow from all
Options +Indexes
</Directory>
ServerName IMASERVER
</VirtualHost>
Does anyone know what is the cause of this?
