28
I installed and created a Postgresql database on ubuntu. I then created the database using the following command:
sudo su postgres createdb mydatabase
However, I can't figure out where the database was initialized. I would like to be able to edit the hba.conf file and postgresl.conf files.
When I view the database using pgadmin I see the following information:
CREATE DATABASE mydatabase
  WITH OWNER = postgres
       ENCODING = 'UTF8'
       TABLESPACE = pg_default
       LC_COLLATE = 'en_US.UTF-8'
       LC_CTYPE = 'en_US.UTF-8'
       CONNECTION LIMIT = -1;
Any thoughts on how I can find the database cluster location?
celenius
  • 387
The postgres.conf file is located here: /etc/postgresql/9.1/main/postgres.conf. In postgres.conf can see a line stating data_directory=<path>
This is the directory where your database files are stored
Alternatively when you are connected to database use
SHOW data_directory
or
pg_lsclusters
to show the directory where your data is stored.
Hope this helps
Rinzwind
  • 309,379
devav2
  • 37,290
ps auxw|grep postgres|grep -- -D
returns:
/usr/lib/postgresql/9.3/bin/postgres -D /var/lib/postgresql/9.3/main
-c config_file=/etc/postgresql/9.3/main/postgresql.conf
on Ubuntu 14.04. That command will work on other variants like Fedora
Rinzwind
  • 309,379
tim
  • 61
