10
This red icon.... It showed up after I upgraded to Ubuntu 12.04LTS; I can't figure out how to ditch it. It seems to be a notification thing. I am at a loss. The icon is this one:
red mark
I clicked it and read this:
An error occurred, please run Package Manager from the right-click menu or apt-get in a terminal to see what is wrong. The error message was:
'Error: BrokenCount>0'.
This usually means that your installed packages have unmet dependencies.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Ceil
  • 103
It's letting you know that the package system is in a broken state (eg. some of the packages are in a broken state). You can try to resolve this by running the following command in a terminal.
sudo apt-get -f install
tgm4883
  • 8,062
I got this same red and white warning icon and identical error code after having tried to install the wrong package accidentally (i386 on amd64 - Ubuntu 12.04 LTS) To resolve I...
  1. ran dpkg --get-selections > ~/Desktop/packages in terminal to get a list of installed packages
  2. removed the package that I had just tried to install using the name of the package as appearing in the above list and this command sudo apt-get purge name-of-package-here
  3. ran the command above sudo apt-get -f install thanks tgm4883
  4. removed some redundant packages with sudo apt-get autoremove (the suggestion appeared in terminal after running the prior command.) Either here or the command before resulted in the warning/error disappearing
  5. I then ran sudo apt-get update which took much longer than usual and everything seems to be back to normal.
Webmonkey
  • 31
Please get correct package name which is been broken. You can use following command to get all package list.
sudo dpkg --get-selections > list.txt
Find correct package name from the list(created in home folder).
And use following command to remove package forcefully.
sudo dpkg --force-all -P PACKAGE NAME
ex- sudo dpkg --force-all -P texlive-pstrick-doc (texlive-pstrick-doc is package name)
Next run update command.
sudo apt-get update
This works for me. Thanks
Eric Carvalho
  • 55,453
Create a new profile/login. Maybe it's related to profile only. I tried everything mentioned in all help on diff websites. At the end, I created a new profile and log in. It's resolved the issue. There is no red circle Icon in the top bar in this profile.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
sanjay
