78
I am updating my Tor on Ubuntu and it states:
Do not use the packages in Ubuntu's universe. You'll need to set up our package repository before you can fetch Tor.
It then states that I have to add this line to your /etc/apt/sources.list file:
 deb http://deb.torproject.org/torproject.org <precise> main
I am uncertain how to add a line to /etc/apt/sources.list.
Braiam
  • 69,112
klint
  • 781
6 Answers6
77
Make a backup copy of your current sources.list file
sudo cp /etc/apt/sources.list /etc/apt/sources.list.bak
Append new line of text to current sources.list file
  • CLI
    echo "new line of text" | sudo tee -a /etc/apt/sources.list
  • GUI (Text Editor)
    sudo gedit /etc/apt/sources.list
  • Paste new line of text on new line at end of current sources.list text file in Text Editor.
  • Save and close sources.list
Don't forget to update in order to use the new repository
sudo apt-get update
jtd
  • 2,385
43
In order to add a third-party repository, you first need the public keys for this repository which in this case you can grab from the Ubuntu key server:
sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 886DDD89
Now you can add the repository in /etc/apt/sources.list.d/ with add-apt-repository:
sudo add-apt-repository "deb http://deb.torproject.org/torproject.org $(lsb_release -s -c) main"
After adding any repository it is always needed to execute
sudo apt-get update
Now you can install the package for Tor itself. For complete instructions on how to install Tor correctly, see How to install Tor?
This procedure can also be reversed.
zerwas
  • 3,943
Easiest way on Ubuntu:
Go to Ubuntu Software Centre > Edit > Software Sources > Add
Paste the line from the Tor website into the APT line box.
You could also manually edit /etc/apt/sources.list, but probably simplest to go through the Software Centre.
Make sure to input the line correctly as well, e.g.
deb http://deb.torproject.org/torproject.org precise main
if you're using 12.04. If something goes wrong edit /etc/apt/sources.list to fix it.
penreturns
  • 5,950
ngm
  • 151
First, make a backup. You can do so with:
in the Terminal. Give your password and press Enter. It will not be shown, not even asterisks. Then run:
gksudo gedit /etc/apt/sources.list
and give your password.
Add the line:
 deb http://deb.torproject.org/torproject.org main
to the bottom of the file and use File->Save to save it.
Then, go back to the terminal and run:
sudo apt-get update
and then continue following the instructions. This command and the one starting in sudo apt-get install may take a while. Additionally, the install command may give a:
Do you want to continue[y/n]?
prompt, where you must type y and press Enter to continue.
nanofarad
  • 20,906
You need not to edit default /etc/apt/sources.list, you better upgrade your Ubuntu to Saucy. Here Tor is in the official repository.
See, my /etc/apt/sources.list:
deb http://us-west-2.ec2.archive.ubuntu.com/ubuntu/ saucy main restricted universe multiverse
deb http://us-west-2.ec2.archive.ubuntu.com/ubuntu/ saucy-updates main restricted universe multiverse
deb http://us-west-2.ec2.archive.ubuntu.com/ubuntu/ saucy-backports main restricted universe multiverse
deb http://us-west-2.ec2.archive.ubuntu.com/ubuntu/ saucy-security main restricted universe multiverse
Only 4 lines.
I'm able to download and install the Tor package:
# aptitude download tor
Get: 1 http://us-west-2.ec2.archive.ubuntu.com/ubuntu/ saucy/universe tor amd64 0.2.3.25-1 [953 kB]
84% [1 tor 799 kB/953 kB 84%]201 URI Done: http://us-west-2.ec2.archive.ubuntu.com/ubuntu/pool/universe/t/tor/tor_0.2.3.25-1_amd64.deb
RecivedHash: MD5Sum:1cb3ed029c169c3a5e528dd7d28cc60f
ExpectedHash: MD5Sum:1cb3ed029c169c3a5e528dd7d28cc60f
Fetched 953 kB in 4s (198 kB/s)
According to http://torstatus.blutmagie.de Tor 0.2.3.25 on Linux, one of the common installations.
user2496
  • 141
Basically sources.list is a text file you want to edit. Linux is all about file you can customize your ubuntu by changing files. so the basic way to edit files(adding or deleting text) is by using some of the text editor like:
  • emacs,gedit(gui based)
  • nano,vi,vim(cli based)
You can install them by typing sudo apt-get install text_editor_name.
type man text_editor_name for reading their mannual pages.
  • If the status is you don't hav permissions, use:
    chmod 777 filename
kashminder
  • 1,380
  • 16
