I'm trying to properly install Ubuntu 12.04.1 LTS 64-bit PC (AMD64) with the alternate install CD ".iso" on a lenovo Thinkpad X220.
Default Hard Disk (with a pre-installed version of Windows 7) has been replaced with a brand new SSD.
The UEFI BIOS of the lenovo Thinkpad X220 is set to "UEFI Boot only" & "USB UEFI BIOS Support" is enabled (I'm using an external USB DVD reader to perform Ubuntu installation).
The BIOS is a Phoenix SecureCore Tiano, BIOS version is 8DET56WW (1.26). The attempts below are made with the UEFI BIOS settings described above. Here's what I've tried so far:
Boot on a live GParted CD
- Create a GPT partition table
- Create a FAT32 partition for UEFI System, set the partition to "EF00" type ("boot" flag)
- Leave remaining space unformated
Boot on Ubuntu 12.04.1 LTS 64-bit PC (AMD64) with alternate CD:
- Perform the install with network updates enabled
- Use manual partitioning
- FAT32 partition created with GParted is used as "EFI System partition"
- Remaining space is set to be used as "Physical volume for LVM"
- Then "Configure encrypted volumes" using the previous "Physical volume for LVM" as the encrypted container, passphrase is setup.
- "Configure the Logical Volume Manager" creating a volume Group using the encrypted container
/dev/mapper/sda2_crypt - Creation of the Logical Volumes "Create logical volume", choosing the previously created volume Group
Assign a mount point and file system to the Logical volumes :
LV-rootfor /LV-varfor /varLV-usrfor /usrLV-usr-localfor /usr/localLV-swapfor swapLV-homefor /homeNOTE: /tmp would be in RAM only using TMPFS
Bootloader step: neither my ESP partition (
/dev/sda1,/dev/sdaor MBR) seems to be the right place for GRUB, I get the following message (X suffix is for demonstration only):
unable to install grub in /dev/sdaX
Executing 'grub-install /dev/sdaX' failed
This is a fatal error.
Finish installation without the Bootloader & Reboot
The system doesn't start, there's no EFI/GRUB menu at startup.
What are the steps to perform a clean and working installation of Ubuntu 12.04.1 Precise Pangolin, 64bit version in U(EFI) mode using the encrypted LUKS + LVM scheme described above?
