I have a Toshiba Satellite R830 laptop with Ubuntu 12.04.1 64 bit. The Fn + F6 and Fn + F7 buttons adjust brightness until I put my laptop on sleep.
On wakeup they don't work any longer. Is there a solution or a workaround to this issue?
To Do
  • 15,833
I found a better solution than the one selected above.
  1. Press Alt + F2 and type gksudo gedit /etc/default/grub.
  2. Find the line than starts with GRUB_CMDLINE_LINUX_DEFAULT= and modify it as follows: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux acpi_backlight=vendor".
  3. In a terminal (ctrl + alt + T) type sudo update-grub.
  4. Reboot.
Problem solved.
More info here: https://wiki.ubuntu.com/Kernel/Debugging/Backlight
Edit
This solution no longer works on 13.10 and 14.04.
A solution that does is creating an xorg configuration file:
  1. In a terminal type sudo touch /usr/share/X11/xorg.conf.d/20-intel.conf to create the file.
  2. Followed by sudo gedit /usr/share/X11/xorg.conf.d/20-intel.conf to edit its content.
  3. Then add the following content and save:
Section "Device"
        Identifier  "card0"
        Driver      "intel"
        Option      "Backlight"  "intel_backlight"
        BusID       "PCI:0:2:0"
EndSection
Log out and in again.
Source: Fix Brightness Control Not Working for Ubuntu 13.10 & 14.04
To Do
  • 15,833
I had the same problem with a Toshiba Portege R935 in 12.04, and I discovered this (not so elegant) workaround:
  • as root (not with sudo but actually changing user: su root), change the value in sys/class/backlight/intel_backlight/brightness
    for instance:
    echo 2937 > /sys/class/backlight/intel_backlight/brightness
Warning: these values are not between 0 and 7 (as the ones in the other directory), but between 284 and 4539, or something like that.
mfiori
  • 73
