I have 348 zip files and I want to find a file that is in one of the zip files, unzip -l doesn't work with wild cards?
How can I list content of all .zip files and grep through the merged list of all files contained in the zips?
Using zipinfo is a fine solution here. However, in general whenever you want to apply a command to a list of files and the command doesn’t accept a list of files, you can use a for loop:
for file in *.zip; do
unzip -l "$file"
done \
| grep "\.zip\|setup"
If the file you are searching for has spaces in it like: your file, in the grep regular expression you need to escape every space with a backslash like grep "\.zip\|your\ file".
You can use zipinfo. It is included in the default Ubuntu installation. Check the manual page for more info.
For example, to look for a pattern setup in a bunch of zip files in current directory, use this command:
find ./ -iname *zip 2> /dev/null -print0 | xargs -0 zipinfo | grep setup
To list the files in a zip archive you can use the following command.
unzip -l
To grep a compressed archive you should use the compressed archive utilities built to work with that type of archive format.
For zip archives:
zipgrep --help
usage: zipgrep [egrep_options] pattern zipfile [members...]
Uses unzip and egrep to search the zip members for a string or pattern.
For tar archives:
zgrep --help
Usage: /bin/zgrep [OPTION]... [-e] PATTERN [FILE]...
Look for instances of PATTERN in the input FILEs, using their
uncompressed contents if they are compressed.
OPTIONs are the same as for 'grep'.
There are a few other tools that work with archives as well. You can pipe the out put into grep to do the same thing.
zcat
zcat my.archive.zip | grep "some text"
Or you can use the search functionality of these tools
zless
zmore
Here's a dash script for searching inside archive files (should also work with: bash, zsh, ksh shells):
Simply call the script with no parameters and the script will prompt for the necessary input:
#!/bin/dash
## Supported shells: dash, bash, zsh, ksh
GetOSType () {
#$1 = returns the type of the current operating system:
case "$(uname -s)" in
*"Linux"* )
eval $1="Linux"
*"Darwin"* | *"BSD"* )
eval $1="BSD-based"
eval $1="Other"
esac
TestIfFileIsText () {
#$1 = input file path
#$2 = returns "true" if the input file is text, "false" otherwise
result="false"
eval current_file=\"\$$1\"
current_file_mime_type="$(file -bL --mime-encoding "$current_file" 2>/dev/null)"
case "$current_file_mime_type" in
*"ascii"* | *"utf"* )
result="true"
esac
eval $2=\"\$result\"
ExtractFirstAndLastPathComponent () {
#$1 = input path
#$2 = returns the first path component
#$3 = returns the last path component
eval current_path="\"\$$1\""
first_path_component=""
last_path_component=""
if [ -n "$current_path" ]; then
#Remove trailing '/' characters:
while [ ! "${current_path%"/"}" = "$current_path" ]; do
current_path="${current_path%"/"}"
done
if [ -z "$current_path" ]; then
eval current_path=\"\$$1\"
fi
last_path_component="${current_path##*"/"}"
first_path_component="${current_path%"$last_path_component"}"
fi
eval $2="\"\$first_path_component\""
eval $3="\"\$last_path_component\""
GetFileSizeInBytes () {
#$1 = the input file path
#$2 = returns the input file size
eval file="\"\$$1\""
[ -z "$OS_TYPE" ] && GetOSType OS_TYPE
if [ "$OS_TYPE" = "Linux" ] || [ "$OS_TYPE" = "Other" ]; then
file_size_in_bytes="$(stat -c %s -- "$file")" 2>/dev/null || { file_size_in_bytes="-1"; }
elif [ "$OS_TYPE" = "BSD-based" ]; then
file_size_in_bytes="$(stat -Lf %z -- "$file")" 2>/dev/null || { file_size_in_bytes="-1"; }
else
fi
eval $2="$file_size_in_bytes"
PrintErrorMessage () {
#Prints the total string parameters received by this function as a single error message:
printf '\n%s\n' "${@}">&2
PrintErrorMessageAndSetError () {
#Prints the total string the parameters received by this function as a single error message and sets the <error> variable to "true":
error="true"
trap1 () {
#Calls the 'CleanUp' function after pressing "CTRL + C / CTRL + Z" and ends all the processes started by this script:
printf "\n""Aborted.\n">>"$print_to_screen"
CleanUp
#kill all children processes, suppressing "Terminated" message:
kill -s PIPE -- -$$ 2>/dev/null
exit
CleanUp () {
#Removes temporary generated files and restores CTRL + C / CTRL + Z and other settings to their original role (i.e. as before running this script):
if [ -n "$TEMPORARY_EXTRACT_PATH" ] && [ -n "$output_dir" ]; then
rm -R -f "$output_dir"'/''TEMP_EXTR_FOLDER''/'* #WARNING: EDIT WITH CAUTION!!!
fi
#Restore "INTERRUPT" (CTRL + C) and "TERMINAL STOP" (CTRL + Z) signals:
trap - INT
trap - TSTP
#Clear the title:
printf "\033]0;%s\007" "">>"$print_to_screen"
RestoreIFS initial_IFS
StoreIFS () {
#Stores the IFS's variable value to the specified $1 variable:
eval $1="\"\$IFS\""
RestoreIFS () {
#Restore the IFS variable to the specified $1 variable value:
eval IFS="\"\$$1\""
GetModifiedFileDateFull () {
#$2 = returns input file modified date
eval input_file=\"\$$1\"
current_modified_date_full="$(stat -c "%y" "$input_file")" || { current_modified_date_full="-1"; }
current_modified_date_full="$(stat -f "%Sm" "$input_file")" || { current_modified_date_full="-1"; }
fi
eval $2=\"\$current_modified_date_full\"
GetModifiedFileDateSSE () {
#$2 = returns input file modified date - Seconds Since Epoch
current_modified_date_SSE="$(stat -c "%Y" "$input_file")" || { current_modified_date_SSE="-1"; }
current_modified_date_SSE="$(stat -f "%m" "$input_file")" || { current_modified_date_SSE="-1"; }
fi
eval $2=\"\$current_modified_date_SSE\"
GenerateMatchedFilesArrays () {
#Generates matched <ARCHIVE PATHS> array and for each path: <MODIFIED DATE SECONDS SINCE EPOCH>, <MODIFIED DATE (LOCAL TIME)>, <SIZE IN BYTES> - arrays:
IFS='
i=0
cd "$initial_dir"
archive_type_1='.zip'
archive_type_2='.tar.bz2'
archive_type_3='.tar.xz'
archive_type_4='.tar.gz'
archive_type_5='.7z'
archive_type_6='.rar'
archive_type_7='.bz2'
archive_type_8='.xz'
archive_type_9='.gz'
archive_type_10='.tgz'
archive_type_11='.tar'
archive_type_0="11"
find_commands_0="$archive_type_0"
extract_to_screen_commands_1="unzip -q -c \"\$file2\" $total_in_archive_file_path_filters"
extract_to_screen_commands_2="tar -xOjf \"\$file2\" --wildcards $total_in_archive_file_path_filters"
extract_to_screen_commands_3="tar -xOJf \"\$file2\" --wildcards $total_in_archive_file_path_filters"\
extract_to_screen_commands_4="tar -xOzf \"\$file2\" --wildcards $total_in_archive_file_path_filters"
extract_to_screen_commands_5="7z e \"\$file2\""
extract_to_screen_commands_6="unrar p \"\$file2\""
extract_to_screen_commands_7="bzip2 -dc \"\$file2\""
extract_to_screen_commands_8="xz -dc \"\$file2\""
extract_to_screen_commands_9="gzip -dc \"\$file2\""
extract_to_screen_commands_10="tar -xOzf \"\$file2\"" ## ERROR: NO OUTPUT GENERATED (LINUX)
extract_to_screen_commands_11="tar -xOf \"\$file2\"" ## ERROR: NO OUTPUT GENERATED (LINUX)
extract_to_screen_commands_0="11"
for current_search_path in $(eval find \"\$search_path\" -prune -exec printf "%s\\\\n" {} + ); do
if [ ! -d "$current_search_path" ]; then
ExtractFirstAndLastPathComponent current_search_path fpc_current_search_path lpc_current_search_path
cd "$initial_dir"; cd "$fpc_current_search_path"; current_search_path="$PWD/$lpc_current_search_path"
for j in $(GenerateSequence 1 $archive_type_0); do
eval current_archive_type="\"\$archive_type_$j\""
eval find_commands_$j="\"find \\\"\\\$current_search_path\\\" -type f -name \\\"*$current_archive_type\\\"\""
done
elif [ -d "$current_search_path" ]; then
cd "$initial_dir"; cd "$current_search_path"; current_search_path="$PWD"
eval find_commands_$j="\"find \\\"\\\$current_search_path/.\\\" -type f -name \\\"*$current_archive_type\\\"\""
done
fi
for file1 in $(\
j=0;\
for l in $(GenerateSequence 1 $find_commands_0); do \
eval current_find_command=\"\$find_commands_$l\"; \
eval current_extract_to_screen_command=\"\$extract_to_screen_commands_$l\"; \
eval current_archive_type=\"\$archive_type_$l\"
PrintJustInTitle "Step 1: Finding $current_archive_type archive files..."; \
GenerateMatchedFilePaths 1|uniq -d;\
j=0;\
PrintJustInTitle "Step 2: Finding $current_archive_type archive files..."; \
GenerateMatchedFilePaths 2|uniq -u;\
done; \
}|sort --numeric-sort;\
PrintJustInTitle "Preparing to store necessary file info..."; \
); do
found="false"
previous_file_path="$current_file_path"
current_file_path="$file1"
if [ -z "$previous_file_path" ]; then
found="true"
else
if [ ! "$current_file_path" = "$previous_file_path" ]; then
found="true"
fi
fi
if [ "$found" = "true" ]; then
i=$(($i + 1))
PrintJustInTitle "Storing necessary file info: file $i..."
eval current_file_path=\"\$file1\"
eval archive_paths_$i=\"\$current_file_path\"
GetModifiedFileDateSSE current_file_path current_file_modified_date_SSE
eval file_modified_dates_SSE_$i=\"\$current_file_modified_date_SSE\"
GetModifiedFileDateFull current_file_path current_file_modified_date_full
if [ ! "${current_file_modified_date_full%"."*" "*}" = "$current_file_modified_date_full" ]; then
current_file_modified_date_full_part1="${current_file_modified_date_full%"."*" "*}"
current_file_modified_date_full_part2="${current_file_modified_date_full#$current_file_modified_date_full_part1"."*" "}"
current_file_modified_date_full="$current_file_modified_date_full_part1$current_file_modified_date_full_part2"
fi
eval file_modified_dates_full_$i=\"\$current_file_modified_date_full\"
GetFileSizeInBytes current_file_path current_file_path_size_in_bytes
eval file_size_$i=\"\$current_file_path_size_in_bytes\"
fi
done;
done
eval archive_paths_0=$i
cd "$initial_dir"
PrintJustInTitle ""
GenerateMatchedFilePaths () {
#For the variable received as parameter (containing a <find command>) -> print all file paths that match the <search criterias> specified by the user:
for file2 in $(\
eval "$current_find_command";\
); do \
j=$(($j + 1)); \
PrintJustInTitle "Step $1: Processing file $j..."; \
GetFileSizeInBytes file2 file2_size_in_bytes; \
if [ "$file2_size_in_bytes" -le "$max_archive_size_in_bytes" ]; then \
not_match="false"; \
for k in $(GenerateSequence 1 $search_strings_array_0); do \
eval current_search_string=\"\$search_strings_array_$k\";\
eval $current_extract_to_screen_command 2>/dev/null|grep -l -i "$current_search_string">/dev/null||{ not_match="true"; break; }; \
done; \
if [ "$not_match" = "false" ]; then printf '%s\n' "$file2"; fi; \
else \
printf '%s\n' "Skipping large archive (max_archive_size_in_bytes=$max_archive_size_in_bytes): $file2...">>"$print_to_screen";\
fi; \
done|sort --numeric-sort
PrintMatchedFilesInfo () {
#For each file in the <ARCHIVE PATHS> array: print the file's: PATH, MODIFIED DATE SECONDS SINCE EPOCH, MODIFIED DATE (LOCAL TIME), SIZE IN BYTES -> for use with 'zenity':
printf '%s\n\n' ">>>">>"$print_to_screen"
sleep 1
for i in $(GenerateSequence 1 $archive_paths_0); do
PrintJustInTitle "Loading files data: file $i..."
eval current_file_path=\"\$archive_paths_$i\"
eval current_file_modified_date_SSE=\"\$file_modified_dates_SSE_$i\"
eval current_file_modified_date_full=\"\$file_modified_dates_full_$i\"
eval current_file_size=\"\$file_size_$i\"
printf "%s \n" "$i"
printf "%s \n" "$(printf '%05d' "$i")"
printf "%s \n" "$current_file_path"
printf "%s \n" "$current_file_modified_date_SSE"
printf "%s \n" "$current_file_modified_date_full"
printf "%s \n" "$(printf '%015d%s' "$current_file_size" "B")"
done
CheckUtilities () {
#Check if any of the necessary utilities (received as string parameters by this function) is missing:
error="false"
for utility; do
which $utility>/dev/null 2>/dev/null || PrintErrorMessageAndSetError "ERROR: the '$utility' utility is not installed!"
done
PrintInTitle () {
#Changes the terminal emulator window title to: $1:
printf "\033]0;%s\007" "$1"
PrintJustInTitle () {
#Changes the terminal emulator window title to: $1 (survives output redirection):
PrintInTitle "$1">>"$print_to_screen"
PressEnterToExit () {
#Waits for the user to press Enter in order to exit:
printf '%s\n' "Press Enter to exit..."
read temp
GenerateSequence () {
#Prints the sequence of numbers $1 .. $2 <-> if $1 value < $2 value:
sequence_start=$(($1))
sequence_end=$(($2))
if [ "$sequence_start" -le "$sequence_end" ]; then
seq $sequence_start $sequence_end
fi
print_to_screen='/dev/tty' #Print text to screen only
set +f #Enable globbing (POSIX compliant)
setopt no_nomatch 2>/dev/null #Enable globbing (zsh)
Q="'"
max_archive_size_in_bytes=100000000 #approx. 100 MB
initial_dir="$PWD"
StoreIFS initial_IFS
GetOSType OS_TYPE
CheckUtilities stat mkdir rmdir unzip cat grep seq find sed file rm uniq sort
#Trap "INTERRUPT" (CTRL + C) and "TERMINAL STOP" (CTRL + Z) signals:
trap 'trap1' INT
trap 'trap1' TSTP
[ "$OS_TYPE" = "Linux" ] || [ "$OS_TYPE" = "Other" ] && {
which gedit 2>/dev/null && {
editor_open_in_same_window_and_wait="gedit -w"
editor_open_in_new_window_and_wait="gedit --new-window -w"
editor_open_new_blank_window_and_wait="$editor_open_in_new_window_and_wait"
which kate 2>/dev/null && {
editor_open_in_same_window_and_wait="kate -w"
editor_open_in_new_window_and_wait="kate -n -w"
} 2>/dev/null || {
PrintErrorMessageAndSetError "ERROR: Text editor not found (gedit / kate)!"
PressEnterToExit
}>&2
} 2>/dev/null || {
[ "$OS_TYPE" = "BSD-based" ] && {
#which bbedit && {
# editor_open_in_same_window_and_wait="open -a bbedit -W"
# editor_open_in_new_window_and_wait="open -a bbedit -n -W"
# editor_open_new_blank_window_and_wait="$editor_open_in_new_window_and_wait"
#} 2>/dev/null || {
# which TextEdit && {
editor_open_in_same_window_and_wait="open -a TextEdit -W"
editor_open_in_new_window_and_wait="open -a TextEdit -n -W"
# } 2>/dev/null || {
# PrintErrorMessageAndSetError "ERROR: Text editor not found (bbedit / TextEdit)!"
# PressEnterToExit
# }>&2
PrintErrorMessageAndSetError "ERROR: Unsupported OS!"
sleep 1
}>&2
}>/dev/null
if [ "$error" = "true" ]; then
#printf "\n"
CleanUp
exit 1
fi
eval find /dev/null $find_search_archive_total_path_filter>/dev/null || {
PrintErrorMessage "ERROR: Invalid find parameters provided!"
CleanUp
exit 1
}>&2
initial_dir="$PWD"
if [ -e '/dev/shm' ]; then
TEMPORARY_EXTRACT_PATH='/dev/shm'
elif [ -e "$HOME" ]; then
TEMPORARY_EXTRACT_PATH="$HOME"
else
PrintErrorMessage "Please provide TEMPORARY_EXTRACT_PATH: "
read TEMPORARY_EXTRACT_PATH
fi
elif [ "$OS_TYPE" = "BSD-based" ] && [ -e "$HOME" ]; then
else
printf '%s\n' "Please provide TEMPORARY_EXTRACT_PATH: ">&2
fi
TEMPORARY_EXTRACT_FOLDER='TEMP_EXTR_FOLDER' # HARDCODED STRING (SHOULD NOT BE CHANGED)
output_dir=""
error="false"
cd "$TEMPORARY_EXTRACT_PATH" && {
output_dir="$PWD"
if [ ! -e "TEMP_EXTR_FOLDER" ]; then
printf '%s\n' "The specified temporary directory: "TEMP_EXTR_FOLDER" - does not exist in the specified location: "$TEMPORARY_EXTRACT_PATH" - do you want to create it? [ Yes / No ] (default=Enter=No): "
read answer
if [ "$answer" = "Yes" ] || [ "$answer" = "yes" ] || [ "$answer" = "Y" ] || [ "$answer" = "y" ]; then
mkdir "TEMP_EXTR_FOLDER" || error="true"
fi
fi
cd "TEMP_EXTR_FOLDER" || {
error="true"
} || error="true"
} 2>/dev/null
PrintErrorMessage "Error: Could not access temporary folder "TEMP_EXTR_FOLDER" in the extract location: "$TEMPORARY_EXTRACT_PATH"!"
PressEnterToExit
exit 1
fi>&2
cd "$initial_dir"
printf "\n"
printf '%s\n' "Current_path = "$initial_dir"";
printf "\n"
printf '%s\n' "Where to search path (unquoted (raw)) (default=Enter=.): "
printf '%s' ">> where to search path: >> "
read -r search_path; [ -z "$search_path" ] && search_path="."
if [ ! -e "$search_path" ]; then
PrintErrorMessage "ERROR: The provided search path: "$search_path" does not exist!"
PressEnterToExit
exit 1
fi>&2
if [ -d "$search_path" ]; then
cd "$search_path" || {
PrintErrorMessage "ERROR: Could not access search dir: "$search_path"!"
PressEnterToExit
exit 1
}>&2
cd "$initial_dir"
fi
printf '\n%s\n' "In-archive file path filter(s): (what file path to lookup in the archive) (default=Enter=""):">>"$print_to_screen"
current_in_archive_file_path_filter="not_defined"
i=0;
while [ -n "$current_in_archive_file_path_filter" ]; do
printf '%s' ">> add in-archive path filter (concatenated internally with logical OR): >> "
IFS= read -r current_in_archive_file_path_filter
if [ -n "$current_in_archive_file_path_filter" ]; then
i=$(($i + 1))
eval in_archive_file_path_filters_$i="$current_in_archive_file_path_filter"
total_in_archive_file_path_filters="$total_in_archive_file_path_filters $current_in_archive_file_path_filter"
fi
done
if [ "$i" = "0" ]; then
i=$(($i + 1))
in_archive_file_path_filters_1='""'
fi
in_archive_file_path_filters_0=$i
printf '\n%s\n' "Search string:";
current_search_string="not_defined"
search_strings_array_0=0
i=0
while [ -n "$current_search_string" ]; do
printf '%s' ">> add search string (RegEx) (concatenated internally with logical AND): >> "
IFS= read -r current_search_string
if [ -n "$current_search_string" ]; then
i=$(($i + 1))
eval search_strings_array_$i="$current_search_string"
fi
done
if [ ! "$i" = "0" ]; then
eval search_strings_array_0=$i
else
search_strings_array_1=""
search_strings_array_0=1
fi
printf '\n%s' "Also open files that match the file path filters but don't match the search string(s) (open them as a secondary group of files (in the same editor window))? [ Yes / No ] (default=Enter=No): "
read answer
open_non_match_string_files="true"
else
open_non_match_string_files="false"
fi
IFS='
cd "$initial_dir"
printf "\n"
pmfi_result="defined"
count=0
while [ -n "$pmfi_result" ]; do
PrintJustInTitle "Loading files data..."
count=$(($count + 1))
pmfi_result=$(zenity --list --separator='|' --multiple --width "1900" --height "900" --hide-column='1' --print-column='1' --column "Hidden column" --column "File Path number" --column "File Path" --column "Modified Date number" --column "Modified Date" --column "File Size" $(PrintJustInTitle "Loading files data..."; PrintMatchedFilesInfo; PrintJustInTitle "Please select archives to preview..."))
sequence="$pmfi_result"
t=0
temp=""
while [ ! "$temp" = "$sequence" ]; do
temp="$sequence"
current_number="${temp%%"|"*}"
t=$(($t + 1))
eval numbers_$t=$(($current_number))
sequence="${temp#*$number*"|"}"
done
numbers_0=$t
j=0
for i in $(GenerateSequence 1 $numbers_0); do
eval current_number=\"\$numbers_$i\"
padded_number="$(printf '%05d' "$current_number")"
eval current_archive_path=\"\$archive_paths_$current_number\"
full_current_archive_path="$current_archive_path"
ExtractFirstAndLastPathComponent current_archive_path fpc_current_archive_path lpc_current_archive_path
cd "$fpc_current_archive_path"
fpc_current_archive_path="$PWD"
ExtractFirstAndLastPathComponent fpc_current_archive_path fpc_fpc_current_archive_path lpc_fpc_current_archive_path
current_archive_name_ext="${lpc_current_archive_path}"
current_archive_name_ext_plus="${current_archive_name_ext}""_extract"
full_current_archive_extract_to_path="$output_dir"'/''TEMP_EXTR_FOLDER'"/$padded_number/$lpc_fpc_current_archive_path/$current_archive_name_ext_plus"
if [ ! -e "$full_current_archive_extract_to_path" ]; then
cd "$output_dir"'/''TEMP_EXTR_FOLDER'
mkdir "$padded_number"
cd "$padded_number"
mkdir "$lpc_fpc_current_archive_path"
cd "$lpc_fpc_current_archive_path"
mkdir "$current_archive_name_ext_plus"
cd "$current_archive_name_ext_plus"
case "$current_archive_path" in
*'.zip' )
unzip "$full_current_archive_path" -d "$full_current_archive_extract_to_path"
*'.7z' )
7z x "$full_current_archive_path" -o"$full_current_archive_extract_to_path/"
*'.rar' )
unrar x "$full_current_archive_path" "$full_current_archive_extract_to_path/"
*'.tar.bz2' )
tar -xvjf "$full_current_archive_path" -C "$full_current_archive_extract_to_path"
*'.tar.xz' )
tar -xvJf "$full_current_archive_path" -C "$full_current_archive_extract_to_path"
*'.tar.gz' | *'.tgz' )
tar -xvzf "$full_current_archive_path" -C "$full_current_archive_extract_to_path"
*'.tar' )
tar -xvf "$full_current_archive_path" -C "$full_current_archive_extract_to_path"
*'.bz2' | *'.xz' | *'.gz' )
cp "$full_current_archive_path" "$full_current_archive_extract_to_path"
*'.bz2' ) bzip2 "$full_current_archive_extract_to_path/""$current_archive_name_ext" -d "$full_current_archive_extract_to_path"; ;;
*'.xz' ) xz "$full_current_archive_extract_to_path/""$current_archive_name_ext" -d "$full_current_archive_extract_to_path"; ;;
*'.gz' ) gzip -d "$full_current_archive_extract_to_path/""$current_archive_name_ext"; ;;
esac
case "${current_archive_name_ext%"."*}" in
*'.tar' )
tar -xvf "$full_current_archive_extract_to_path/${current_archive_name_ext%"."*}" -C "$full_current_archive_extract_to_path"
#rm "$full_current_archive_extract_to_path/${current_archive_name_ext%"."*}"
rm "$output_dir"'/''TEMP_EXTR_FOLDER'"/$padded_number/$lpc_fpc_current_archive_path/$current_archive_name_ext_plus""/""${current_archive_name_ext%"."*}" #WARNING: EDIT WITH CAUTION!!!
esac
esac >/dev/null 2>/dev/null
else
cd "$full_current_archive_extract_to_path"
fi
new_group=""
for m in $(GenerateSequence 1 $in_archive_file_path_filters_0); do
eval current_in_archive_path_filter=\"\$in_archive_file_path_filters_$m\"
IFS=' '
for current_group_no in 1 2; do
IFS='
if [ "$current_group_no" = "2" ] && [ -z "$new_group" ]; then
break
fi
for current_in_archive_file_path in $(eval find . -type f -path $current_in_archive_path_filter|sort --numeric-sort); do
TestIfFileIsText current_in_archive_file_path in_archive_file_is_text
if [ "$in_archive_file_is_text" = "true" ]; then
matched_group="1"
eval current_search_string="$search_strings_array_$k"
cat "$full_current_archive_extract_to_path/$current_in_archive_file_path"|grep -l -i "$current_search_string">/dev/null||{ matched_group="2"; break; }
done
if [ "$matched_group" = "$current_group_no" ] && ( ! ( [ "$open_non_match_string_files" = "false" ] && [ "$current_group_no" = "2" ] ) ); then
esc_full_current_extr_file_path="$(printf '%s\n' "$full_current_archive_extract_to_path/$current_in_archive_file_path"|sed "s/'/$Q\"\$Q\"$Q/g")"; new_group="$new_group"" ""'$esc_full_current_extr_file_path'"
fi
fi
done
IFS=' '
done
done
if [ -n "$new_group" ]; then
j=$(($j + 1))
eval groups_$j=\"\$new_group\"
eval matched_archive_paths_$j=\"\$current_archive_path\"
fi
done
groups_0=$j
matched_archive_paths_0=$j
first_time="true"
for i in $(GenerateSequence 1 $groups_0); do
eval current_group="\"\$groups_$i\""
if [ "$first_time" = "true" ]; then
{ eval $editor_open_new_blank_window_and_wait & }
sleep 0.5
{ eval $editor_open_in_same_window_and_wait "$current_group" & }
first_time="false"
else
{ eval $editor_open_in_new_window_and_wait "$current_group" & }
fi
sleep 0.5
done
IFS='
done
PrintJustInTitle "Exiting..."; sleep 1; CleanUp
cd "$initial_dir"
}>>"$print_to_screen"
Note: In order to be able to display a customized (personal) terminal emulator window title - some terminal emulators, such as konsole, require one initial additional step - for the konsole terminal emulator, this step is:
Konsole -> Settings -> Configure Konsole ... ->
-> Enable option "Show window title on the titlebar"
