In my ubuntu 12.04, the graphviz is not the latest version(2.29). I need some features available in the latest version of graphviz. I tried to install the graphviz version 2.29, which requires libgraphviz4(>=2.18). I anyhow installed libgraphviz4 and installed graphviz 2.29. For that I have to remove packages libcdt4 and libpathplan4.
Now whenever I try to generate graph, I get some problems: For e.g.:
dot -Kfdp -n -Tpng -o samplePOS.png forcePOS.dot
It says:
dot: error while loading shared libraries: libgvc.so.6: cannot open
shared object file: No such file or directory
neato -Tps -o sample_1.ps sourcedot.gv
It says:
neato: error while loading shared libraries: libgvc.so.6: cannot open
So, I am looking for some ways so that I can run graphviz 2.29 in my ubuntu 12.04.
Tim
  • 33,500
bidur
  • 83
First a warning for using PPA (mainly unstable)
The below PPA: ppa:dperry/ppa-graphviz-test is an unstable PPA. So, you are given warning.
Use this commands in a terminal to install the unstable 2.29 version of graphviz.
sudo apt-add-repository ppa:dperry/ppa-graphviz-test
sudo apt-get update
sudo apt-get autoremove graphviz
sudo apt-get install graphviz
If you get this error "graphviz : Depends: libgraphviz4 (>= 2.18) but it is not going to be installed", run the following
sudo apt-get remove libcdt4
sudo apt-get remove libpathplan4
Anwar
  • 77,855
Ubuntu 12.04 here.
What worked for me is:
  1. Remove the following packages
  2. Install libgraphviz4
    http://www.graphviz.org/Download_linux_ubuntu.php
  3. Install graphviz
Anwar
  • 77,855
anh_ng8
  • 131
Since you mess with some libraries i advice you to remove graphviz and install again
sudo apt-get remove graphviz
sudo apt-get remove graphviz-dev
sudo apt-get remove graphviz-doc
This is a same situation for other user
