I downloaded Avast using terminal command wget http://files.avast.com/files/linux/avast4workstation_1.3.0-2_i386.deb and the download and installation was successful.
Then I chose check updates(database) from the interface. As soon as the updates were downloaded the following problem started.
An error occurred in avast! engine: Invalid argument
What should I do to correct the problem?
Lucio
  • 19,191
  • 32
  • 112
  • 191
This is a known problem in Avast. You need to increase the maximum amount of shared memory allowed.
  • To load it without rebooting sudo sysctl -w kernel.shmmax=128000000
  • To make it permanent, edit the file /etc/sysctl.conf (gksudo gedit /etc/sysctl.conf), and add this line to the end of the file kernel.shmmax = 128000000
Sepero
  • 4,627
I use Puppy Linux Slacko and this solution worked for me.
I've a 4GB memory. So this solution, I guess will work for computers with higher memory not low ones.
Insert
SHMMAX=`sysctl -n kernel.shmmax`
[ $SHMMAX -lt 128000000 ] && sysctl -w kernel.shmmax=128000000
in /usr/lib/avast4workstation/bin/wrapper-script.sh
Then Open terminal and type
sysctl -w kernel.shmmax=200000000
Hit Enter.
And then start avast. Now Avast works!
