I used windows installer to install Ubuntu and it was getting errors on bootup. Well that didn't work, I guess I'll try and boot from a USB to install it. However, after messing around with uninstalling (aka deleting Ubuntu folder after booting into Win7) I cannot get rid of the launch option.
There is nothing in Computer Management because I never actually booted into Ubuntu to create space on my HDD for the OS. I can't just uninstall using Program and Features in Control Panel (because I already deleted the folder)
Now everytime I boot up it gives me the options of booting into Windows 7 or Ubuntu, how do I disable this page/get rid of the Ubuntu launch option?
user68186
  • 37,461
rQw
It sounds like you have a Wubi system--that is, that you installed Ubuntu while booted into Windows.
If that is the case, you should be able to remove Ubuntu, including the selection for Ubuntu in the Windows boot menu (that comes up when you start your computer), by going to Add/Remove Programs (in the Control Panel, in Windows), and removing Ubuntu.
If you've already uninstalled Ubuntu and it worked, except that you still get to "choose" between Windows and Ubuntu when you start up, then this question, which @user68186 found, should help you:
If you find you're unable to uninstall Ubuntu in Add/Remove Programs, you got errors when you tried to do so, or it never appeared in Add/Remove Programs, then you can manually uninstall it as explained in this section of the Wubi Guide.
Eliah Kagan
  • 119,640
