I initially tried running Ubuntu off of a USB flash drive, but the files got deleted. Now when I boot my laptop it shows both Windows 7 and Ubuntu operating systems, but the Ubuntu system says it's missing a file and can't run it.
After the files were lost I downloaded Ubuntu on a CD and installed it on my hard drive following the instructions on the installation menu, but the same error message shows up whenever I try to run Ubuntu. It says I'm missing some files, as if it were still trying to run it from a USB.
How can I remove the nonfunctional Ubuntu from my boot menu?
mickmackusa
  • 852
  • 20
Go inside Ubuntu and run the command
sudo update-grub
This will update the menus. If not then kindly reinstall the OS on the exact same location. When reinstalling, do not repartition, do not select format, select same / and /home partitions as before.
OR
try using the ubuntu recovery mode.
One of the 3 should work for you. Thank you.
Avinash Raj
  • 80,446
CR2
  • 434
