49
I have noticed that some of my files have an asterisk at end.
Does the asterisk at the end have any particular significance? I think they are mostly executable and displayed in green by the ls command.
You will see that ./bkmp* and ./bkmp0* have an asterisk at the end. They are executable bash scripts.
Here's my output:
drwxr-xr-x 7 username username  4096 Oct  2 18:28 ./
drwxr-xr-x 8 root     root      4096 Oct  2 09:25 ../
-rw-r--r-- 1 username username  3724 Sep 22 03:06 .bashrc
-rwxr--r-- 1 username username   319 Sep 22 03:42 .bkmp*
-rwxr--r-- 1 username username   324 Sep 29 23:30 .bkmp0*
drwx------ 2 username username  4096 Sep 17 13:52 .cache/
-rw-r--r-- 1 username username   675 Sep 17 13:37 .profile
drwx------ 2 username username  4096 Sep 22 10:10 .ssh/
drwx------ 2 username username  4096 Sep 24 19:49 .ssh.local/
drwxr-xr-x 2 username username  4096 Sep 22 04:10 archives/
drwxr-xr-x 3 username username  4096 Sep 24 19:51 home/
-rw-r--r-- 1 username username 27511 Sep 24 19:51 username_backup.20120924_1908.tar.gz
Roly
  • 280
vfclists
  • 1,949
5 Answers5
60
If you are just using ls with no arguments, it appears that you are using an alias for ls. To get the same output, I need to use ls -lF. From the ls manpage:
-F, --classify
          append indicator (one of */=>@|) to entries
-l     use a long listing format
The symbols mean the following:
/: directories
@: symbolic links
|: FIFOs
=: sockets
*: executable files
To test if you are using an alias, use alias ls. Mine (which is the Ubuntu default) says:
$ alias ls
alias ls='ls --color=auto'
More information on using aliases can be found here.
reverendj1
  • 16,403
Those files are indeed executable. It's because you have (or your .bashrc file has) specified the -F option. Unfortunately the manpage is not very clear on this:
-F, --classify
But as far as I know * is for executables, / for directories, = for sockets, > for doors, @ for symbolic links, | for FIFOs and nothing for regular files.
Also, the colour green is because you have (or your .bashrc file has) specified the --color option.
Silke
  • 1,182
Looks like your ls is configured to denote executable files.
http://forums.whirlpool.net.au/archive/961288
Maybe your ls is aliased with something extra. check
alias ls
Nate
  • 554
I am thinking like they are executables and they starts running if you start your system . something like startup scripts .
Raja G
  • 105,327
  • 107
  • 262
  • 331
-1
  • *: Install the package with all dependencies.
  • -d: for access to the service.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
Hari
