I am trying to install CUDA drivers on kubuntu 12.04, but in order to do so I need to remove nvidia drivers (which come in with the distro). The problem I have is that while doing so it also removes kubuntu-desktop, which is disasterous (though cuda installs ok). I had the same problem when trying Linux Mint 13 KDE.
I followed the link here: http://sn0v.wordpress.com/2012/05/11/installing-cuda-on-ubuntu-12-04/ and noticed that some people have come across this problem as well, but no solution has been found yet - except for not installing the cuda, lol.
I also tried this:
sudo apt-get purge nvidia-common
only to get the same warning of being about to remove the desktop:
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
    kubuntu-desktop nvidia-common
0 upgraded, 0 newly installed, 2 to remove and 435 not upgraded.
After this operation, 197 kB disk space will be freed.
Do you want to continue [Y/n]? n
My question is - can you remove the nvidia drivers in a way that does not remove kubuntu-desktop (or ubuntu-desktop) at the same time? Or do I have to go with killing the desktop and then install the it again after cuda is installed? Wouldn't it affect other apps, which depend on kubuntu-desktop?
I need CUDA for my CG work and so any help would be really welcome, thanks!
Phil_thy
Following this link helped:
http://chrislaidler.blogspot.com/2012/05/cuda-429-and-kubuntu-1204.html
Phil_thy
kubuntu-desktop is a meta-package. I.e. it's a virtual package, which has other packages as dependencies. Removing this package doesn't remove the packages which depend on it.
So, the answer is: don't worry that kubuntu-desktop package is removed.
warvariuc
  • 2,335
