Possible Duplicate:
Dash search gives no result
I've Ubuntu 12.10.1 LTS x62 fresh of installation... My dash is empty, search doesn't work and applications list is empty.
If I run the Ubuntu Software Center it freeze in a blank screen.
I tried with:
  • restart
  • reinstall of unity packages
  • deleting ~/.local/share/zeitgeist folder
  • other tricks found in the other askubuntu answers
UPDATE:
From ~/.xsession-errors
I/O warning : failed to load external entity "/home/francesco/.compiz/session/10699c9c27649d05db134910329935534100000027470033"
Initializing session options...done
(compiz:2813): GConf-CRITICAL **: gconf_client_add_dir: assertion `gconf_valid_key (dirname, NULL)' failed
** (zeitgeist-datahub:3070): WARNING **: zeitgeist-datahub.vala:227: Unable to get name "org.gnome.zeitgeist.datahub" on the bus!
EDIT:
Deleting .cache folder solves the Ubuntu Software Center blank screen issue, thanks to jokerdino!!
Try this:
sudo apt-get install unity-lens-applications unity-lens-files unity-lens-music unity-lens-video
If not, use:
zeitgeist-daemon --replace
Frantique
  • 8,673
