Refer to : Launch an application in Windows from the Ubuntu desktop
I was wondering if Takkat could elaborate on the actual execution i.e. howto in the script file.
This will be greatly helpful. Thanks in advance
my script file InternetExplorerVM.sh looks like this, execution is
/path/to/InternetExplorerVM.sh "C:\Program Files\Internet Explorer\iexplore.exe"
#!/bin/bash
# start Internet Explorer inside of a Windows7 Ultimate VM
echo "Starting 'Internet Explorer' browser inside Windows7 virtual machine"
echo ""
sleep 1
echo "Please be patient"
VBoxManage startvm b307622e-6b5e-4e47-a427-84760cf2312b
sleep 15
echo ""
echo "Now starting 'Internet Explorer'"
##VBoxManage --nologo guestcontrol b307622e-6b5e-4e47-a427-84760cf2312b execute --image "$1" --username RailroadGuest --password bnsf1234
VBoxManage --nologo guestcontrol b307622e-6b5e-4e47-a427-84760cf2312b execute --image "C:\\Program/ Files\\Internet/ Explorer\\iexplore.exe" --username RailroadGuest --password bnsf1234 --wait-exit --wait-stdout
echo ""
echo "Saving the VM's state now"
VBoxManage controlvm b307622e-6b5e-4e47-a427-84760cf2312b savestate
sleep 2
#Check VM state
echo ""
echo "Check the VM state"
VBoxManage showvminfo b307622e-6b5e-4e47-a427-84760cf2312b | grep State
exit
My apologies for any mistakes, this is my first time posting on askubuntu.Thanks a ton in advance. This has been very helpful. Need this for BNSF guests, their Mainframe emulator works exclusively on Java enabled Internet Explorer.
He's basically saying you can do this:
  1. Create a Virtual Machine, like a Windows virtual machine.
  2. Login to the virtual machine.
  3. Switch the virtual machine into "seamless" mode
  4. Save the state of the virtual machine in the main Virtual Box window.
  5. Create a bash script with the VBoxManage commands, so that you can do something like ./runinwindows "C:\\some\\path\\executable.exe"
For example:
#!/bin/bash
# Start the VM
VBoxManage startvm "<Name_of_VM>"
# Run the executable
VBoxManage --nologo guestcontrol "<Name_of_VM>" execute --image "$1" --username windowsuser --password password --wait-exit --wait-stdout
# Save the current machine state for the next time you run the script.
VBoxManage controlvm "Name_of_VM" savestate
Then you could run a Windows executable (in this case) in your terminal, but it would actually be running in a virtual machine.
Sly
  • 762
I wrote a script to control a virtual machine using VBoxManage. you can execute commandS using the script like this:
./vmcontrol.sh -m [VMName] [Your Command]
The script:
#!/bin/bash
#Creation du script vmcontrol.sh
function execute
    vmname=\$1;
    command=\$2;
    shift 2;
    VBoxManage --nologo guestcontrol \$vmname execute --image \$command --username root --password root --wait-exit --wait-stdout --wait-stderr -- \$@ 2>&1  ;
param=\$1;
#Execution d'une commande
if [ \$param = "-e" ]
then
    command=\$2;
    shift 1;
    execute "Xubuntu" \$@ ;
#Execution d'une commande dans une vm donnée
elif [ \$param = "-m" ]
    then
        vmname=\$2;
        command=\$3;
        shift 1;
        execute \$@
#Allumer une machine virtuelle donnée
elif [ \$param = "-s" ]
    then
        vmname=\$2;
        VBoxHeadless --startvm \$vmname;
elif [ \$param = "-c" ]
    then
        vmname=\$2;
        VBoxManage clonevm Xubuntu --mode machine --name \$vmname --basefolder /home/VMs --register ;
elif [ \$param = "-r" ]
    then
        vmname=\$2;
        VBoxManage unregistervm \$vmname  --delete ;
elif [ \$param = "-vbox" ]
    then
        startx virtualbox;
elif [ \$param = "-i" ]
     then
    vmname=\$2;
        if [ \$vmname = "vms" ]
            then
            VBoxManage list vms
        elif [ \$vmname = "runningvms" ]
            then
            VBoxManage list runningvms
        else
            #Erreur
            echo "error in commmande";
        fi
elif [ \$param = "-sv" ]
    then
        vmname=\$2;
        VBoxManage startvm \$vmname ;
elif [ \$param = "-p" ]
    then
    vmname=\$2;
    VBoxManage controlvm \$vmname  acpipowerbutton;
    else
        #Erreur
fi
muru
  • 207,228
