11
The question very simple and short. I am following this article to install OpenOffice headless:
sudo apt-get install openoffice.org-headless openoffice.org-writer openoffice.org-draw
And I get the following error :
Reading package lists... Done
Building dependency tree
E: Unable to locate package openoffice.org-headless
E: Couldn't find any package by regex 'openoffice.org-headless'
UPDATE:
apt-cache search openoffice.org
output: http://pastebin.ubuntu.com/1262902/
Anwar
  • 77,855
5 Answers5
17
Ubuntu switched to libreoffice instead of openoffice quite a while ago.
Install libreoffice-common, then you can run the libreoffice service by adding the "--headless" runtime argument.
$ /usr/bin/libreoffice --headless
The rest of that article should be compatible if you replace "openoffice.org" with "libreoffice" across the board.
Eric
  • 909
12
Install OpenOffice following the instruction given at their Website.
The installation procedure is as follows:
  1. First Download the openOffice.org all in one tar package. You should select Your OS (For me Linux 64-bit (x86-64) DEB), Language and Version. Then click on Download full installation button to get a .tar.gz file
  2. Then extract the .tar.gz file into a suitable directory. I downloaded in my home directory. You can extract it using a command like this (replace the file name with the exact name you downloaded)
    tar xf Apache_OpenOffice_4.1.2_Linux_x86-64_install-deb_en-US.tar.gz
  3. Then open a terminal and go the the directory containing the .deb files. If you extracted in Home directory, the command is
    cd ~/en-US/DEBS/
  4. Then install all the .deb files with the command:
    sudo dpkg -i *.deb
  5. Since, OpenOffice 2.3 it can be started in headless mode. So, you can start it in headless mode with the command
    soffice --headless
Hope this will help.
Tested again in 16.04. It works as before
Anwar
  • 77,855
Make sure that you have first completely removed LibreOffice, then follow Olive Twist's installation instructions and that should work for you.
Download open office headless from here
Although it is the Hardy package, but it should work for you
OpenOffice.org Headless install:
apt-get install openoffice.org-core
