11
Possible Duplicate:
How to install a .tar.gz (or .tar.bz2) file?
I have downloaded eclipse-jee-juno-linux-gtk.tar.gz file, but i don't know how install it.
It is easy, just extract it. You can do right click extract here or in the terminal
tar -zxvf eclipse-jee-juno-linux-gtk.tar.gz
You will see the eclipse file in the folder double click it and that is all.
You can also use a normal GUI for this as well, So in most cases its a simple as right clicking on the file and selecting "Extract" or similar..
But as a further note, You generally do not want to have your applications sitting in your user directory/desktop/downloads... You shold move the extracted folder depending on your distro and then link via a normal menu icon/entry.
Else one day you might decide to empty your downloads folder and delete your installation/custom settings... and possibly projects for some who dont pay attention to folder/locations.
Angry 84
  • 103
Diego
  • 611
Just decompress the downloaded file in the folder you want (can be /opt/eclipse)
To decompress it, you can do it via command line:
Or from your folder
Right click on the file / extract here / move it where you want to install it
Then, you can add a shortcut to your desktop or add it to your Applications' menu doing:
Right click in Applications/Edit Menus
Go to your prefered section (usually programming)
New Item / Browse to /opt/eclipse/eclipse (if you installed it there)
Good luck!
luso
  • 211
