Possible Duplicate:
Lock and Unlock from USB disk (pendrive)
When i use Windows, there is a program I use called Predator that locks my PC when I remove a certain USB flash drive. It then unlocks the computer when I reinsert it.
Is there any program like this for Ubuntu?
Well, a module called PAM (Pluggable Authentication module) can be customized to achieve your need. A beautiful article is available on linuxconfig describing this in detail.
The steps are:
  1. Install PAM
    $ sudo apt-get install pamusb-tools libpam-usb
  2. Add USB device to PAM config
    $ sudo pamusb-conf --add-device <my-usb-stick>
  3. Select your volume and "Y" to save
  4. Define user for PAM auth
    $ sudo pamusb-conf --add-user <ubuntu-user>
  5. Select and "Y" to save
  6. Configure PAM
    $ sudo gedit /etc/pam.d/common-auth
  7. Add the line below and save
    auth    sufficient      pam_usb.so
  8. Test the PAM auth
    $ su ubuntu-user
  9. Lock when disconnected
    $ sudo gedit /etc/pamusb.conf
  10. Modify the block "user" block to look like:
    <user id="ubuntu-user">
          <device>
                  my-usb-stick
          </device>
          <agent event="lock">gnome-screensaver-command -l</agent>
          <agent event="unlock">gnome-screensaver-command -d</agent>
     </user>*
cuttlefish could be one solution to do it as @maythux suggested. I really can't comment on its capabilities, I prefer to stay away from 3rd party apps as much as possible.
Peachy
  • 7,235
  • 40
  • 47
Fr0zenFyr
  • 330
Don't know of any program but you can create a simple script that can do that like in this example:
http://www.techienote.com/2011/03/lock-unlock-ubuntu-desktop-using-usb-drive.html
You can use cuttlefish
It does what you need plus more advanced options see this link to learn about
