Possible Duplicate:
How do I make my own customized Ubuntu version?
I've made an Ubuntu installation from minimal with no X - everything is based on CLI and added some apps to it. I've custom designed it so it can be like a LAN-based web server and serve the apps/data as necessary.
I'm now trying to make a distro of this setup and tried with Remastersys. While the process completed OK and he LiveCD works well, the install option does nothing more than booting it in LiveCD mode.
One of the lines I see while Remastersys is in the process,
Installing the Ubiquity GTK frontend grep: /etc/x11/default-display-manager: No such file or directory
I even tried removing Remastersys followed by a reinstall with no luck. "Binged" around for some help and cam across some interesting stuff which says Ubuntu does not have CLI based install process so it's not Remastersys's fault. Some suggestion was that I install ubiquity-frontend-debconf before installing Remastersys. I even tried this but no luck.
I do not need any graphical installer and there's no options to choose from at the time of install.
I don't understand why they say Ubuntu can only install with a graphical installer, when Ubuntu Server minimal edition does not seem to use a graphical installer (correct me if I'm wrong, pls)
How would I be able to go about with this, pls?
check this wiki from official Ubuntu Documentation
Your option is alternate cd
